almost done changing radiator. HELP AT THE END, bleeding/air pocket/fan problem
Old Aug 13, 2005 | 10:56 AM
SHystrdyGSRtdy's Avatar
Default almost done changing radiator. HELP AT THE END, bleeding/air pocket/fan problem
is there somethign wrong with my car? i just changed my radiator on my car to another oem type one because my old one was leaking fluid pretty badly. anyways, i've let it idle for over 20 min, within that time, i was filling up the radiator with the cap off as bubbles came up/level gets lower.
now, my problem is that my fan won't turn on. that whole time idling for 20 min, the fan didn't turn on once. the a/c is on the hot position, everything is off. i turned the a/c on while on the hot position once just to test that the fans were working, and yes they were. now where can i stop filling up my radiator because the fans won't turn on and the fluid is just boiling with the cap off.
Old Aug 13, 2005 | 11:09 AM
new2novas's Avatar
Default Re: almost done changing radiator. HELP AT THE END, bleeding/air pocket/fan problem (SHystrdyGSRtdy
what i do to bleed air out is CRACK the cap, don't have it off fully, or if you have an overflow tank leave the cap off of that, then make sure its topped off, rev it up to 2 or 3 grand, hold it for a few seconds then let off, that bleeds it off fast, should be done in a few minutes....
Old Aug 13, 2005 | 12:05 PM
i thought you were supposed to let it idle, not rev it?
Old Aug 14, 2005 | 09:32 AM
need to know soon. will be driving 400 miles in the heat, and i don't want to be stranded.
Old Aug 15, 2005 | 01:52 PM
new2novas's Avatar
rev it up some
JDM_SOHC
Oct 12, 2008 07:24 AM
Dat1BVtecN
Mar 8, 2007 06:55 PM
krayziehuh
Oct 19, 2003 01:39 PM
envious1320
Mar 9, 2003 04:50 PM
metal-x
Aug 29, 2002 05:19 AM
