How about that POWER!
Old Aug 13, 2005 | 10:15 AM
DualCamDan's Avatar
Default How about that POWER!
well, we got this crx for a nice price, but we're having problems with the batt. staying charged. i'm not really sure what the problem is... pulled out the old batt. and replaced it w/ a new one (put the old one in a friends car, he hasno problems with it), then we thought alt. nope, we swapped it w/ his and we still have the same problem... took it to a shop and they said bad grounds... re-did the grounds, but STILL Does it....
what happens is it'll start all day long, BUT when you leave it sit for a day or so it wont start up, drained batt.!
~what is there that could be draining the batt. when its off?
nothing is lit up power wise... everyone said the radio, but it had the same problem without a radio in it!
please help!
Old Aug 13, 2005 | 10:28 AM
J.Lloyd's Avatar
Default Re: How about that POWER! (singlecamdan)
O.K. so here is what you do, you take a multimeter and open up the fuse box, using the leads of the multimeter you probe the fuse terminals (with the fuse out of course) one fuse at a time. Placeing one lead on each terminal (of course each fuse has two prongs, then when you find the one that is drawing power you can narrow down your search. Hope my explanation isnt to confusing, good luck with it, electrical problem can be a bitch, ive seen some people give up and just disconect the battery when the car is sitting. Oh and woot woot for my first post ever!
Old Aug 13, 2005 | 10:44 AM
teknohatchie91's Avatar
Default Re: How about that POWER! (J.Lloyd)
It sounds like your alternator is dead. Happens more often than you think... I changed mine like about a week ago, took about 1 hour. Its a pita to get out with the engine in though...good luck!
Old Aug 13, 2005 | 10:52 AM
ILcrxsi1's Avatar
I tell doctors what to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.Lloyd &raquo;</TD></TR><TR><TD CLASS="quote">O.K. so here is what you do, you take a multimeter and open up the fuse box, using the leads of the multimeter you probe the fuse terminals (with the fuse out of course) one fuse at a time. Placeing one lead on each terminal (of course each fuse has two prongs, then when you find the one that is drawing power you can narrow down your search. Hope my explanation isnt to confusing, good luck with it, electrical problem can be a bitch, ive seen some people give up and just disconect the battery when the car is sitting. Oh and woot woot for my first post ever!</TD></TR></TABLE>
Almost a good explanation, but he left one thing out. Make sure you are checking for amps not voltage, he didn't mention that before. It does sound like you have a parasitic drain problem though. Somthing is slowly using up power while your car is off.
Old Aug 13, 2005 | 10:57 AM
dephtone's Avatar
I have pretty much the same problem with my current daily driver. The passenger side door locks are stuck on unlock and it slowly drains my battery, to prevent this, I just unhook the neg battery cable, and then rehook it up everything I want to go somewhere. You can try that as well, to see if you are able to start it after a day or so. As J.Llyod said, sounds like you have a slight drain in the electrical somewhere.
Old Aug 13, 2005 | 12:33 PM
bagpipe goatee's Avatar
yep, small drain somewhere, called parasitic drain.
the multimeter will tell you which circuit some wire is shorting out in (or a component could be left on)
then investigate what's on that circuit.
just like with dephtone's problem.
dephtone: if i were you, i'd just unplug the door lock switch or whatever, you don't need them, and it'd be easier that undoing the battery. but, of course, i'm lazy.
Old Aug 13, 2005 | 01:47 PM
DualCamDan's Avatar
Default Re: How about that POWER! (illcrxsi1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">Quote, originally posted by J.Lloyd »
Almost a good explanation, but he left one thing out. Make sure you are checking for amps not voltage, he didn't mention that before. It does sound like you have a parasitic drain problem though. Somthing is slowly using up power while your car is off.</TD></TR></TABLE>
check every fuse? or just the main fuses? it's actually my friends car, i just do a lot of work on it... i dont think she'll be up for dis conecting the batt. all the time...
Old Aug 13, 2005 | 02:04 PM
Skinflute22's Avatar
check every fuse.. the underhood ones and under dash..
ILcrxsi1's Avatar
Disconnect every fuse, i would start with the accessory fuses. Just keep going until you find the one that is using power. Make sure you have everything turned off when you do this too. Keep the doors shut etc. dome lights and such will mess up your test results. With everything off you shouldn't get a reading of more than a couple milliamps from each circuit that you test. If you pull a fuse and there is more than lets say 50ma being used on that circuit it means that something in that circuit is using power. Check to see what that fuse is for and it will really help you narrow down the search for the problem.
Old Aug 13, 2005 | 02:13 PM
chickenandpickles's Avatar
i had the same problem a few months ago..it was a failing alternator...
Old Aug 13, 2005 | 02:38 PM
charliev's Avatar
it isnt the alternator he has swapped that out before... dont just disconnect the battery it would be worth it to fix... find the problem using a multi-meter...Good Luck
Old Aug 13, 2005 | 03:22 PM
DualCamDan's Avatar
Default Re: (charliev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charliev &raquo;</TD></TR><TR><TD CLASS="quote">it isnt the alternator he has swapped that out before... dont just disconnect the battery it would be worth it to fix... find the problem using a multi-meter...Good Luck</TD></TR></TABLE>
like charliev said, we already did the alt. we swapped in one for another car that had no problems. the other car is still doing fine!
leem23vtec
Feb 10, 2022 09:35 AM
Colby Schwedes
Honda Ruckus and Scooters
May 31, 2019 06:02 PM
bwr93 civic
Nov 12, 2015 10:15 AM
HedgeCore
Audio / Security / Video
Jun 10, 2005 12:01 PM
cd5_2NR
Jul 1, 2004 01:38 PM
