Tire size for Prelude with 17x7.5's
Old Aug 13, 2005 | 09:19 AM
dacosta's Avatar
Default Tire size for Prelude with 17x7.5's
Has anyone tried the following combination on a Prelude?
225/45-17 on a 17x7.5 & 45 offset
Any rubbing or issues?
I bought my wife a 2nd hand lude and it came with 17x7.5 Rota's wrapped around 205/40/17 tires and whenever my wife and kids ride in the car, I become really nervous because it appears as if the tires are rolling not just on the thread of the tire but the sidewall as well.
Please advise.
Thanks,
Darwin
**Edit...the car is lowered sligthly on Tokiko Shocks & Struts***
Modified by dacosta at 10:35 AM 8/13/2005
Old Aug 13, 2005 | 09:29 AM
dacosta's Avatar
Default Re: Tire size for Prelude with 17x7.5's (dacosta)
I did do several searches for wheels, tires, 225/17, 17, 225 and have been having trouble finding the answers. Any help and advise would be appreciated.
Thanks Again,
Darwin
Old Aug 13, 2005 | 10:23 AM
h22apwrd95's Avatar
I had 225/45/17's on 17x8 wheels on my 4th gen lude. It rubbed when I had my kyb's with eibach sportlines, but not with my tein s-tech/kyb combo. I'm guessing this is a 5th gen though. tsw hockenheim. I believe 42mm offset.
Mike
Old Aug 13, 2005 | 11:42 AM
lakerschamp2000's Avatar
it's depend on how low your car is,
205-45-17 is fit best, no rubbing issue if you have 45 offset, even with 3" dropped.
Old Aug 13, 2005 | 12:57 PM
Lude454's Avatar
Default Re: Tire size for Prelude with 17x7.5's (lakerschamp2000)
first question is what type of tire are you running i run 205/40/17 and my lude is lowered 2 1/2 inchs but i have yoko preda spec 2 tires if you have cheap tires they might be the reason
but you said your rim is 17*7.5 so i would guess you might need a 215 or 225 i would think 215 is better but not to sure
good luck
Old Aug 14, 2005 | 01:27 AM
dacosta's Avatar
Thanks you guys for all the replies.
I've went ahead and purchased some new tires late yesterday and decided to go with 215/40-17 for my wife's 97 Lude.
So far so good.
Maybe next time, I'll give 215/45-17 a try to see how they fit.
Thanks!!!
Darwin
Old Aug 14, 2005 | 05:26 PM
215-40-17 has smaller over all diameter than 205-50-16, therefore, you'll end up spend more gas.
Speedometer(mph) Actual(mph)
205-50-16 215-40-17
30 29.6
40 39.5
50 49.3
60 59.2
70 69.1
80 79
90 88.8
100 98.7
Old Aug 14, 2005 | 05:39 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dacosta &raquo;</TD></TR><TR><TD CLASS="quote">Thanks you guys for all the replies.
So far so good.
Thanks!!!
Darwin</TD></TR></TABLE>
You lucked out, b/c 215/40/17 is the proper tire size for a 5th gen prelude. don't even bother with the 215/45/16 unless you want the extra rim protection.
superiorx120
Nov 28, 2010 10:00 AM
dbobby2b
Mar 28, 2009 03:50 PM
MyHotsh
May 30, 2008 06:41 PM
cuban
Jul 20, 2006 11:15 PM
sab_showlude
May 10, 2002 03:01 PM
