GSR block girdle in LS block
Old Aug 13, 2005 | 12:45 AM
Simple's Avatar
Default GSR block girdle in LS block
I picked up a GSR block girdle and 3 main caps from the GSR... can i pretty much just bolt the GSR main caps and girdle on my LS block with no problems as long as i match up the bearings?
Old Aug 13, 2005 | 01:36 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: GSR block girdle in LS block (Simple)
No, you have to install the girdle, torque it to spec and have the mains align honed, it is by no means a bolt on.
Old Aug 13, 2005 | 07:24 PM
Simple's Avatar
Default Re: GSR block girdle in LS block (PURPLETERROR)
even with the original GSR main caps for the girdle?
Old Aug 14, 2005 | 02:22 AM
yes
Old Aug 14, 2005 | 02:39 PM
BigBodySmith's Avatar
I dont think the LS windage tray will clear the girdle, I know for my LS/Vtec, I purchased a new pan, p/u, tray, and girdle from Len.
Old Aug 15, 2005 | 04:17 PM
MikeGRIS's Avatar
you will need a GSR or Type R windage tray, oil pick up and Oil Pan. And It is NOT, I said Not a direct bolt on, take it to a machine shop.
Old Aug 22, 2005 | 08:04 AM
Ruthless671's Avatar
Default Re: GSR block girdle in LS block (MikeGRIS)
Yup, thats what my homie did with his LS/Vtec. Took the block to the machine shop to get it installed and aligned. good luck
Agito
Sep 14, 2007 01:11 PM
marcussmith26
Dec 5, 2005 05:28 PM
TegRaceR98
Nov 12, 2004 10:27 AM
Speedz
Aug 16, 2002 05:19 PM
JDM EG
Jan 20, 2002 05:06 PM
