91 std brake conversion question
Old Aug 12, 2005 | 09:49 PM
quintanaporvida's Avatar
Default 91 std brake conversion question
hey hows it going?
well i got a brake question that i tried searching but failed in receiving any info. i looked through the really helpful FAQ questions that i usually turn to for any questions that i have thats been answered already, and i failed again to find anything helpful. so now im buggin. i got a 91 std and wanna get rid of the stock brakes especially the rears. i was wondering what all you peoples would recommend? would you go for the DA brakes, Si brakes, or if its possible to do any other kinda brake conversions that would be really good. if theres a thread out there that you people can direct me to i would appreciate it or if you wanna put your 2 cents i will appreciate that as well.
thanks for your time
Old Aug 12, 2005 | 10:00 PM
jisu009's Avatar
Default Re: 91 std brake conversion question (quintanaporvida)
You can swap 91 CRX SI rear trailing arm or 90-93 integra trailing arms.
That being said, the rear drums are lighter and work much better.
Old Aug 13, 2005 | 12:05 AM
anyone else got some feed back i would appreciate it
Old Aug 13, 2005 | 03:14 AM
StorminMatt's Avatar
Default Re: 91 std brake conversion question (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">That being said, the rear drums are lighter and work much better. </TD></TR></TABLE>
I don't know about the rear drums being BETTER. But the fact of the matter is that they get the job done just as well as rear disk would for well over 90 percent of people. Rear disks are, in most cases, unnecessary overkill. And yes, they ARE heavier. Especially if you go with the light, aluminum 1984-1987 HF brack drums.
Old Aug 13, 2005 | 05:06 PM
i def dont want the rear drums im going to be doing alot of canyon driving so im def gonna go with all around disc do you guys recommend using 90-93 DA brakes and just upgrading the rotors pads calipers and so on?
red4re
Dec 15, 2008 10:22 AM
jdmEF91
May 22, 2006 10:59 AM
b16rex91
May 5, 2006 08:40 PM
the-pepsi-man
Jan 8, 2005 01:07 AM
91sifreak
Aug 30, 2001 12:56 PM
