O MAN ..........
Old Aug 12, 2005 | 09:02 PM
EF_ST@TUS's Avatar
Default O MAN ..........
When i start my car the check engine light comes on and the idle gets really low, when i push throttle it bogs down and almost dies..... this only happens sometimes and if i shut off the car and restart it goes away. wiring? I don't know, i need to get new water pump, spark plugs, dist. rotor, flush motor, etc... thanx..
Old Aug 12, 2005 | 09:19 PM
EFRue57's Avatar
Default Re: O MAN .......... (Lost_in_a_world_so_cold)
what code are you throwing?
Old Aug 12, 2005 | 09:20 PM
ryan89crx's Avatar
Default Re: O MAN .......... (EFRue57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">what code are you throwing?</TD></TR></TABLE>this would help a lot
Old Aug 12, 2005 | 09:46 PM
b18_crx's Avatar
Default Re: O MAN .......... (ryan89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">this would help a lot</TD></TR></TABLE>
agreed!
Old Aug 13, 2005 | 03:53 PM
EF_ST@TUS's Avatar
Default Re: O MAN .......... (b18_crx)
i will have to wait till it happens again.. until then replacing: Water pump, Dist. rotor, plugs, timing belt, i guess just drain and refill fluids... all needed to be done.
Old Aug 13, 2005 | 03:54 PM
EF_ST@TUS's Avatar
could it have been electrical? my battery termial wire was corroded and falling off.
Old Aug 13, 2005 | 05:42 PM
ef8 h0!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost_in_a_world_so_cold &raquo;</TD></TR><TR><TD CLASS="quote">could it have been electrical? my battery termial wire was corroded and falling off.</TD></TR></TABLE>
yes, but probably not. need ecu codes.
Old Aug 13, 2005 | 07:32 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost_in_a_world_so_cold &raquo;</TD></TR><TR><TD CLASS="quote">i will have to wait till it happens again.. until then replacing: Water pump, Dist. rotor, plugs, timing belt, i guess just drain and refill fluids... all needed to be done.</TD></TR></TABLE>
Well, your patience is admirable, but in this case, you don't need to wait. If I understood you correctly, your CEL (check engine light) comes on and when you turn the car off and back on again, the CEL is gone. If thats the case, the ecu stores what CEL it threw. So check the ecu even though it is not throwing a CEL. And tell us how many times it blinks.
Old Aug 14, 2005 | 11:11 AM
EF_ST@TUS's Avatar
Default Re: O MAN .......... (Mach69)
OK i know that i dont know a lot of stuff but please bear with me guys i know you were all in my place at one time.. i am doing all this stuff by myself..... i dont have anyone to help me so i come to this forum to get help i'm not sarcastic or rude why do i get attitude all the time? i got pissed off last time and i got was banned from honda-tech. thank you for your time.
Modified by Lost_in_a_world_so_cold at 1:07 PM 8/14/2005
Old Aug 14, 2005 | 11:16 AM
Stoich EG2's Avatar
you didnt check the code yet. you need to check it. go to autozone or kragen to get your code pulled as we all know you have no knowledge of doing so.
Old Aug 19, 2005 | 07:17 AM
EF_ST@TUS's Avatar
Default Re: O MAN .......... (ADVAN EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 &raquo;</TD></TR><TR><TD CLASS="quote">you didnt check the code yet. you need to check it. go to autozone or kragen to get your code pulled as we all know you have no knowledge of doing so.</TD></TR></TABLE>
nicko360
15
Nov 2, 2007 04:24 AM
hondahp21
Dec 11, 2006 10:39 PM
Keith Pierson's bitch
Oct 12, 2005 07:17 PM
djgalloway73
May 11, 2005 05:08 PM
CivHatchH22
12
Mar 24, 2004 09:35 PM
