gt35r spool .63 vs .83 on b16?
Old Aug 12, 2005 | 08:15 PM
downeyballz's Avatar
Default gt35r spool .63 vs .83 on b16?
i have a built b16 with a mini-me manifold. it was 81mm, 9:1 pistons. my .82 gt35r spooled very late (6-6.5k rpm). when i did a compression test the number were super low (120's). so i rebuilt the motor and now have 84mm 9.7:1 pistons. im hoping this will help my late spool problems. but how much of a diffrence will it make if switched to .63 housing? is it worth the money?
Old Aug 12, 2005 | 08:49 PM
Default Re: gt35r spool .63 vs .83 on b16? (downeyballz)
has anyone switched between the two, or experinced bothe sizes
Old Aug 12, 2005 | 09:45 PM
DRIVENRacing's Avatar
i run the 82 on my 1.8l and it spools geat... i hit full 23 psi @ 5600ish
Old Aug 12, 2005 | 11:33 PM
Muckman's Avatar
Moderator in Chief
Default Re: (adSPEED)
what manifold and exhaust?
Old Aug 13, 2005 | 05:00 AM
N20civicB18's Avatar
I was told there would be no more then a 500rpm difference. so I went with the 10cm2 (about .73)
Old Aug 13, 2005 | 06:36 AM
Default Re: gt35r spool .63 vs .83 on b16? (N20civicB18)
i have a love fab mini-me manifold and a full 3" exhaust. i just dont know if my motor has enough displacment to spool the turbo quickly enough.
Old Aug 13, 2005 | 06:37 AM
b16sedan's Avatar
If it spooled at 6500 with the 81mm motor it should be spooling about 500 RPM's quicker with the 84mm bore. I would probably swap to a .63
i was wondering the spool diffrence. i dont know if 500rpms is worth the $300 for a new housing. would the .82 housing be worth anyting if i were to sell it?
Old Aug 13, 2005 | 06:43 AM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering the spool diffrence. i dont know if 500rpms is worth the $300 for a new housing. would the .82 housing be worth anyting if i were to sell it?</TD></TR></TABLE>
A new housing shouldn't be 300 bucks, and you can try and trade with someone on here. I'm sure theres somebody with a .63 that wants to trade up to a .82.
Old Aug 13, 2005 | 06:48 AM
Default Re: gt35r spool .63 vs .83 on b16? (b16sedan)
the best price i could find was $300. the gt35r housings are like 2x compared to normal t3 housings. if you can find a better price let me know
Old Aug 13, 2005 | 12:08 PM
bump
Old Aug 13, 2005 | 05:28 PM
JDogg's Avatar
the 63 will hit about 30psi around 5300 rpms assuming you have a good exhaust manfiold and big exhaust.
deffinatly wouldnt get the 82 on a b16 unless you plan on turning 12k rpms
Old Aug 13, 2005 | 05:43 PM
Default Re: gt35r spool .63 vs .83 on b16? (JDogg)
this is a street car so i dont think it will ever see 30psi, it will hardly ever see any race gas. also how much of a diffrence will changing the compression from 9:1 to 9.7:1
Old Aug 13, 2005 | 06:59 PM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">also how much of a diffrence will changing the compression from 9:1 to 9.7:1</TD></TR></TABLE>
it wont
Old Aug 13, 2005 | 08:10 PM
Silverhatch's Avatar
i have a gt35re .63 .. I will trade for a bigger one. i wanted to go bigger but recieved the wrong turbo in the mail.
Old Aug 13, 2005 | 08:17 PM
Default Re: (Silverhatch)
is yous 3" outlet, i also need to see it if will fit because i dont know if turbo you have is ball bearing
Old Aug 13, 2005 | 08:18 PM
Default Re: (downeyballz)
so compression doesnt make a diffrence in spool?
Old Aug 13, 2005 | 09:43 PM
my turbo is ballbearing .. on the exaust side irt says .63
Old Aug 14, 2005 | 06:26 AM
is it a 3" outlet, 4-bolt, t3? have any pics? i would be intrested in trading.
the onth thing that through me off was that you said you had a gt35rE
Old Aug 14, 2005 | 06:29 AM
jayman322's Avatar
i am also in the market for a .63 4 bolt gt35r, let me know condition etc.
Old Aug 14, 2005 | 07:06 AM
bump
cheapturbo.com sells them, but you have to call its not on there web site
Old Aug 14, 2005 | 08:47 AM
Default Re: gt35r spool .63 vs .83 on b16? (rota92)
dont take this the wrong way, but-
isnt a gt35r a little overkill on a d16? i didnt think thoes reved high enough or made enough power to get the most out a big turbo. how high (rpms) can a d16 go. and how much power are you making at your boost level
Old Aug 14, 2005 | 08:53 AM
in theory a d16 could rev higher, it has less moving parts. a z6 rev limit is like 7600 stock i think, higher then an LS. I know people that rev there z6's to 9k all day long with no problems. so I wouldnt say revs are an issue, and hes making boost at around 5100 so it is deffinitally usable.
Old Aug 14, 2005 | 10:59 AM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">so compression doesnt make a diffrence in spool?</TD></TR></TABLE>
nope
Old Aug 15, 2005 | 05:36 AM
i though that d series motors were rev limited because of there longer stroke.
im just trying to learn a little more about d-series.
bump for more opnion on exhaust housing
