Funny Sound
Old Feb 22, 2002 | 05:07 AM
whagkangmakulet's Avatar
Default Funny Sound
I just recently bought a used Hatch as a spare car while I mess around with my first hatch. I'm getting this funny claking noise when my car is on gear.. it's more like if I have a load to my engine. It sounds like Rod bearings to me, can someone verify this or anyone has a feedback on this one. thanks
[Modified by whagkangmakulet, 5:51 PM 2/22/2002]
Old Feb 22, 2002 | 08:51 AM
Default Re: Funny Sound (whagkangmakulet)
ANYONE! PLS
Old Feb 22, 2002 | 10:15 AM
RexB16's Avatar
hmm, that could be rod bearing, try adding some oil to it to see it it quiets down. warning tho, the incresed oil pressure may break the already potentially weakend rod.
Old Feb 22, 2002 | 11:38 AM
Perfectionist's Avatar
You're sure it's not just pinging?
BTW, adding oil to the proper level will not increase oil pressure unless it was so low that the pick-up was sucking air.
Old Feb 22, 2002 | 04:22 PM
91cvcsi's Avatar
Default Re: Funny Sound (Perfectionist)
may be pilot bearing on the flywheel or a main bearing in the tranny...ive had 3 civics do that to me and 2 times it was the main bearings in the tranny and another time it was the pilot bearing...hth
Old Feb 22, 2002 | 04:41 PM
fixhondas's Avatar
Could be piston slap- is it worse cold?
Old Feb 23, 2002 | 10:15 AM
RexB16's Avatar
well if its knocking that bad, my guess is that adding a quart wont be enough.
LudemanDan
Mar 26, 2008 07:40 PM
boostedeghatch
15
Mar 2, 2005 12:55 PM
toooslow
Oct 15, 2003 10:47 AM
espanol
Apr 20, 2003 10:04 AM
dustin
Oct 23, 2002 12:06 PM
