Everyone with a b16 Chime in!! doing a swap in 2 days.
Old Aug 12, 2005 | 04:46 PM
RaysBoomBoomLude's Avatar
Default Everyone with a b16 Chime in!! doing a swap in 2 days.
ok, I got my mounts. my shift linkage, all hasport.
WHAT DO I DO ABOUT THE THROTTLE CABLE?!?!
i hear you use a 90-93 integra cable.
I hear you can use a SOHC Cable, just gotta mod the bracket?
post up what you have, and what you did. thanks everyone!!!!
Old Aug 12, 2005 | 06:00 PM
eda6's Avatar
Default Re: Everyone with a b16 Chime in!! doing a swap in 2 days. (LaFawnduh)
Yep the dx cable works if you mod the bracket. I wanted a shorter throttle so i used one from the 98 itr.
Old Aug 12, 2005 | 09:53 PM
Default Re: Everyone with a b16 Chime in!! doing a swap in 2 days. (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">Yep the dx cable works if you mod the bracket. I wanted a shorter throttle so i used one from the 98 itr. </TD></TR></TABLE>
How do I mod the bracket???
Old Aug 12, 2005 | 09:58 PM
Rywire's Avatar
http://www.droppedcrxsi.com has all the info you would need
Old Aug 12, 2005 | 10:12 PM
Default Re: Everyone with a b16 Chime in!! doing a swap in 2 days. (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">http://www.droppedcrxsi.com has all the info you would need</TD></TR></TABLE>
I read that alot, it says use a 90 inegra cable. I know I can use one of those. but Ide like to know how people used there DX cable. thanks for the info though, Ill actualy Bookmark it.
Old Aug 12, 2005 | 10:25 PM
NikoZai's Avatar
by routing it differently... simple as that. Loop it over the driver side wheel well back around to the throttle..
Isn't clean but it works.
Old Aug 12, 2005 | 10:28 PM
Default Re: Everyone with a b16 Chime in!! doing a swap in 2 days. (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">by routing it differently... simple as that. Loop it over the driver side wheel well back around to the throttle..
Isn't clean but it works.</TD></TR></TABLE>
awesome, thanks for the info.
Old Aug 12, 2005 | 10:29 PM
Rywire's Avatar
Yup, thats correct for the throttle cable, but if you mean the clutch cable, I simply trimmed some of the rubber out of the bottom so it would fit the j1 tranny.
Old Aug 13, 2005 | 02:33 AM
M15's Avatar
M15
Hey dropped CRX what header did you use on your B16 CRX, and did you have any O2 bung work or Crossmember clearance issues?
Old Aug 13, 2005 | 07:48 AM
Rywire's Avatar
Default Re: Everyone with a b16 Chime in!! doing a swap in 2 days. (M15)
When I had that eng, and that car for that matter I had a 99-00 civic si dc header (4-2-1) , and had no clearence issues. I did however weld in 2 bungs in factory locations for my 2 o2's when I was obd0
Ryan
boostincoupe
Feb 17, 2007 04:41 PM
CRXified
Apr 30, 2005 01:19 PM
CNSK
Aug 4, 2004 06:29 AM
90hbvtec
Nov 13, 2003 02:47 PM
RAWB
Jun 23, 2003 12:59 PM
