TPS acting up during hot weather?
Old Aug 12, 2005 | 03:47 PM
builthatch's Avatar
MiG-21 superfan
Default TPS acting up during hot weather?
today was hot as all hell; it seems when my engine has been running for 20 mins+, the tps voltage at light throttle jumps around....today was the first day this has done it, then again, i have not driven my car this long all summer lol
when i say light throttle, i mean less than 5-10%; it'll jump around and hit 0%, even tho im giving it gas, then jump up...really all over the place....but once over 10%+, it's fine...
voltage closed and running is .470V-.475V, full throttle 4.5V it doesnt jump around tho until it's really hot like i mentioned.
12.3:1 NA SOHC
Could it be the heat? i drove it home from the gym tonight and it was fine. 15 minute trip, but its considerably cooler than it was at high noon....
i am going to swap one out for another to see what haps.
Modified by builthatch at 3:17 PM 8/15/2005
Old Aug 12, 2005 | 05:33 PM
-=Zeqs=-'s Avatar
Default Re: TPS acting up during hot weather? (builthatch)
Dunno...but my car has been acting up too as of late. Are you on a stock ECU?
Old Aug 12, 2005 | 05:44 PM
builthatch's Avatar
MiG-21 superfan
Default Re: TPS acting up during hot weather? (-=Zeqs=-)
apexi power FC stand alone.
Old Aug 14, 2005 | 05:19 PM
builthatch's Avatar
MiG-21 superfan
up
Old Aug 16, 2005 | 01:12 PM
-=Zeqs=-'s Avatar
I'm running a Hondata s100 and something is up. Sometimes the car will shut off on me while I'm driving. I mean, straight up, shut off while in gear with my foot on the gas pedal. It won't restart either until I completely turn it off, and back on. Strange *** ****.
Old Aug 16, 2005 | 07:37 PM
builthatch's Avatar
MiG-21 superfan
well, the other day i noticed that the voltage at closed throtte was .470-.475....
so, tonight i adjusted it, while hot, so that the slightest touch of the pedal/ throttle rotor showed on the percentage, and idle/ closed throttle is now at .520
interestingly enough, i drove the car around for 20 mins or so and it acted fine. also, the Power FC idle stability is now catching with the AC and lights on...something that it was not doing for some time since i adjusted the throttle cable tension the other day in my initial investigation regarding the jumping voltage (i messed with tension because i noticed, when hot, it would stick at times, anywhere from .05 percent to 6 percent, and i'd have to pull back under the pedal to take the tension off) so, when i adjusted the tension so there was no added tension pulling the rotor and cracking the t-plate at idle when hot, i noticed the idle stability feature, which pulls/ adds timing to keep idle at set points with varions loads, was not kicking on with electrical load + AC on...
now it is.
so, we will see. it was raining tonight and significantly cooler than the other day when it was acting funny, so i still need to run it for 20mins+ during a hot spell to see what the real deal is.
Daniel Potts
Engine Management and Tuning
Mar 19, 2017 04:13 PM
boosted199
Apr 23, 2016 06:33 PM
builthatch
Aug 15, 2005 05:29 PM
DurboDug93
May 5, 2005 11:31 AM
BoostedGSRBubble
Mar 8, 2003 10:21 PM
