diy dual stage boost controller with GM boost solenoid
I have a gm boost solenoid and pig tail lying around and was just wondering if any
body has used one for a dual stage boost controller setup using a single manual boost controller and a preset wastegate spring for low boost? any info would be great. chris
will not work, the gm solenoid is made to be controlled by a pwm output, that is how it changes boost, on/off would just be open and closed.
wow thats some bad information you just gave him.
yea you can do that
I design EBCs, all you need is 12 / ground doesnt matter if its PWM's ground or not.
Nick
yea you can do that
Nick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner »</TD></TR><TR><TD CLASS="quote">wow thats some bad information you just gave him.
Nick</TD></TR></TABLE>
no, its not bad information. the gm solenoid is designed to be operated in 10-85% duty cycle. applying 12v directly(100%) isn't the intended purpose of the solenoid. Besides, the solenoid is a normally open solenoid, unlike most other controllers.
The solenoid will work just fine doing 0% or 100%. I wouldnt do 86-99% because it would probably just end up closing to 100% or overheating.
I agree with your duty cycle stats, but I dont agree with your logic.
make a simple pwm output for the gm selenoid.
I haven't tested it yet.
https://honda-tech.com/zerothread?id=1130513
CJ
CJ
rice a roni
Apr 20, 2007 05:56 AM
