fitting a 92-95 hb/coupe roll cage in my 95 sedan
How hard do you guys think it'll be to fit a 92-95 roll cage in a 95 sedan? Shouldnt it be some what of a close fit though?
i was looking at the 6pt Full Race pre fab roll cage set up, if not how hard would it be for the autopower set up?
I missed the "sedan" part, (far-sided
I think that HB and 2-doors share the same wheel base but the 4 door is a little bit longer and maybe wider.
so I think that the end result would not make it to the wheel wells in the back, I think that the "rear feet" would be angled wrong comming off the main hoop and lets say that you used the autopower bolt in, the main hoop (and therefore everything else) might not be wide enough either.
Maybe someone can confirm wheelbase/width diferences between the two but you might have to order one that will fit your sedan.
)I think that HB and 2-doors share the same wheel base but the 4 door is a little bit longer and maybe wider.
autopower doesn't make one huh...
did you try http://www.kirkracing.com
i drive a honda
Oct 21, 2012 10:22 PM
skribblah
Sep 9, 2003 01:27 PM
2.2L EH2
Jul 1, 2002 10:12 PM
