88 crx....... starter tested good no turn over
Old Aug 12, 2005 | 12:35 PM
SomeDude56's Avatar
Default 88 crx....... starter tested good no turn over
Starter tested good but the engine wont turn over...Good battery, ignition?, relays?, wonering if someone had a similar problem ona crx and had some info to make this **** a lil easier.
thanks
Old Aug 12, 2005 | 12:40 PM
mahatma's Avatar
Default Re: 88 crx....... starter tested good no turn over (SomeDude56)
What does it do when you turn the key?
Old Aug 12, 2005 | 12:47 PM
SomeDude56's Avatar
Default Re: 88 crx....... starter tested good no turn over (mahatma)
nothin
Old Aug 12, 2005 | 01:11 PM
mahatma's Avatar
Well if you don't hear the fuel pump priming in back, then it's probably the main relay under the dash.
If nothing at all happens (no dash lights or anything), then it's probably a ground. I'd start at the main battery negative. Make sure the battery has juice of course.
Old Aug 12, 2005 | 01:29 PM
SomeDude56's Avatar
thanks man, itll be the first stuff i check.
Old Aug 12, 2005 | 01:34 PM
EFM_ookie's Avatar
mine wouldnt start after i bust ed a rod in half!!! haha
Old Aug 12, 2005 | 04:12 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">Well if you don't hear the fuel pump priming in back, then it's probably the main relay under the dash.
It would still turn over though.
If nothing at all happens (no dash lights or anything), then it's probably a ground. I'd start at the main battery negative. Make sure the battery has juice of course.</TD></TR></TABLE>
Also verify tranny to frame ground is in place and in good condition. Sometimes these have been messed with.
Xextr3meX
Nov 6, 2018 11:55 AM
ek coupe
10
Mar 5, 2010 05:02 PM
i_VTEC
Jul 19, 2008 09:06 AM
robotosan
May 5, 2005 07:07 PM
wambus
Feb 12, 2004 03:09 PM
