Self Diagnostic
Old Aug 12, 2005 | 12:18 PM
Vandalrugby's Avatar
Default Self Diagnostic
I am looking for a link or a diagram. I use to have it but for some reason I cannot find it. You jumper out the Engine Control and the instruments lights flash a sequence and that sequence tells you whats up. For instance the inst light will flash 3 long 5 short and that is the code for a certain problem. I have a 94 Accord any help would be great. Thanks for your time.
Old Aug 13, 2005 | 02:44 AM
Duane_in_Japan's Avatar
Default Re: Self Diagnostic (Vandalrugby)
92-95 Accord, Civic, Civic Del Sol and Prelude
Retrieving Codes
With ignition off, insert jumper wire in service check connector terminals, located behind right side of dash on Accord, Civic and Civic Del Sol and near center console on Prelude.
Turn ignition switch to ON position. Diagnostic Trouble Codes (DTCs) will be indicated by a series of long and short flashes on MIL.
The number of long flashes indicates the number in the 10s column. The number of short flashes indicates the number in the 1s column. For example, 4 long flashes followed by 3 short flashes would indicate DTC 43.
Nassrif
Nov 21, 2013 08:01 AM
2.3AccordSOHC
Jun 24, 2008 06:17 AM
Ntense90crxsi
Dec 24, 2005 02:49 PM
IdotheSHOCKER
Aug 19, 2002 06:06 PM
