Towing while the engine is out
Old Aug 12, 2005 | 09:55 AM
AK77's Avatar
Default Towing while the engine is out
Hey guys, after taking the engine out can I put the wheels back on and towe it to another place. I mean is it safe for me to take it off the jack stands and let it sit on the wheels while there is no engine in the car and no axels attached?
Old Aug 12, 2005 | 10:51 AM
dwnthehatch's Avatar
Default Re: Towing while the engine is out (AK77)
It's fine.
Old Aug 12, 2005 | 02:10 PM
msmotorsports's Avatar
As long as none of the suspension components are loose you will be good.
Old Aug 13, 2005 | 08:05 AM
AK77's Avatar
Thank you very much guys!!!
Old Aug 13, 2005 | 10:51 AM
gsrious's Avatar
if there is no axles on... meaning no hub bolt(no axle nut) wouldn't the suspension component be able to fall apart.
**i mean even if you torque the wheel on... the whole hub can pull off of the suspension components.
Old Aug 13, 2005 | 10:27 PM
RHDintegXsi's Avatar
Default Re: (gsrious)
he hubs are pressed in pretty good..i would flatbed it to be on the safe side though
Old Aug 14, 2005 | 12:10 PM
JDMB16A4ME's Avatar
yeah as long as the suspension is intact youre fine. mine sat like that for 6 months.
its also a hell of a way to go fred flinstone on your ride, just cut a whole in the hood and wear some good running shoes and your ready for a hell of a workout.
Old Aug 14, 2005 | 05:36 PM
rustyhatch's Avatar
Default Re: Towing while the engine is out (JDMB16A4ME)
flatbed only my friend. dont take any chances with losing a wheel while in route.
Old Aug 14, 2005 | 06:26 PM
AK77's Avatar
flatbed???
Old Aug 14, 2005 | 07:13 PM
drdisco69's Avatar
Default Re: (AK77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK77 &raquo;</TD></TR><TR><TD CLASS="quote">flatbed??? </TD></TR></TABLE>
Flatbed.
Old Aug 14, 2005 | 08:10 PM
luti's Avatar
Default Re: (drdisco69)
you dont need a flat bed. I just towed my project car more than 30 miles saturday morning with no motor in the bay. saved me between 25 and 50 bucks too.
Old Aug 15, 2005 | 06:38 AM
AK77's Avatar
So when you towed your car without the engine in the bay, was it rolling on all four wheels or front 2 lifted???
Old Aug 15, 2005 | 07:06 AM
luti's Avatar
Default Re: (AK77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK77 &raquo;</TD></TR><TR><TD CLASS="quote">So when you towed your car without the engine in the bay, was it rolling on all four wheels or front 2 lifted???</TD></TR></TABLE>
front lifted
Old Aug 15, 2005 | 09:13 AM
cchhrriiiss's Avatar
Default Re: (luti)
Without axles and axle nuts. Theres no preload on the front wheel bearings. The bearings could come apart. Not safe to tow with a chain or towhooks, but Flatbed or tow truck are safe.
Old Aug 15, 2005 | 08:33 PM
AK77's Avatar
Thank you very much for clarifying guys, this really helps and I hope it helps other people looking for the same info!!! God bless you guys and may he become real to you all!!!
Old Aug 16, 2005 | 05:49 AM
JimBlake's Avatar
Default Re: (AK77)
If you have outer CV joints, even broken ones, put them thru the wheel bearings & tighten an axle nut to proper torque. Even on a flatbed, the wheel bearing is supporting the weight of the car.
You can try to find a great big bolt & nut to hold it together the same way. But the wheel bearing has to be clamped together with the hub or you risk ruining the bearing. Or even losing a wheel...
Old Aug 16, 2005 | 04:21 PM
AK77's Avatar
Well, the suspension is all intact, lower & uuper control arms + tie rod, so won't that just hold the wheel in place on a flatbed? Why would I need cv-joints???
Old Aug 17, 2005 | 03:39 AM
JimBlake's Avatar
Default Re: (AK77)
Control arms & ball joints hold the steering knuckle in place. The CV joint, or more specifically the outer axle stub, holds the bearing together & holds the hub into the bearing.
beyer
Oct 31, 2006 10:54 AM
dj626
Jun 30, 2005 07:21 PM
CRXed
20
Sep 23, 2004 06:55 PM
DPK
May 5, 2003 03:03 PM
HuskerHybrid
Mar 10, 2003 10:51 AM
