throttle cable on a b16
sup guys . i just pulled my 1.5 sohc out my cx hatch
and i installed my b16a2 swap.. its all done but im having a problem with my throttle cable. I believe its too short. Ive done a gsr swap into a vx hatch and i used the stock cable. Do i gotta swap throttle cables? if so which one should i use that will work for my car thanks guys
Come on June you got my number you should of called me i heard you went through hell with this swap. You dont need a new cable i never swapped cables all you need is a new bracket trust me i just made one for my hatch 2 weeks ago.
From: With my POS D15B2, Whereever whenever, United States
When I put a z6 from a b16, i had to get a cable
d series cable are shorter, you can fab one, but it comes out not working like oem
steve can you make me one? ill give u a call. you got any hubs laying around? need a driver side assembly.. my ball joint is done..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrida3 »</TD></TR><TR><TD CLASS="quote">sup guys . i just pulled my 1.5 sohc out my cx hatch
and i installed my b16a2 swap.. its all done but im having a problem with my throttle cable. I believe its too short. </TD></TR></TABLE>
Either get an Integra throttle cable or you can get the HCP throttle cable bracket (half the price of the throttle cable and easier/faster to install).
yah thanks steve you helped.. alot. man. especially with my ball joint problem.. I put mad pressure on the rotor and my girl got a bolt on there so im getting it finished in a day or two
