car doesnt like to start when its hot outside
Old Aug 12, 2005 | 05:09 AM
aws140's Avatar
Default car doesnt like to start when its hot outside
my car doesnt like warm starts. in the morning or evening when its cool outside itll start right up, but in the hot times of the day it wont start. this has become a major probem for me. what do i need to do? thanks.
the car is a 94 accord non vtec
Old Aug 12, 2005 | 05:15 AM
deserthonda's Avatar
Default Re: car doesnt like to start when its hot outside (aws140)
it sounds like a main relay problem..............when car does not start, verify if it is lack od spark or fuel ,,if lack of fuel i would chk relay ,
Old Aug 12, 2005 | 05:23 AM
P_Adams's Avatar
Default Re: car doesnt like to start when its hot outside (deserthonda)
Beat me to it Dh
P
Old Aug 12, 2005 | 06:59 AM
aws140's Avatar
i know how to check for fuel and spark, but if it is in fact the fuel, where is the relay?
Old Aug 12, 2005 | 07:20 AM
P_Adams's Avatar
Default Re: (aws140)
... Left side of dashboard in vicinity of fusebox. It's behind the cruise control module, I believe it has a five wire connector. The bottom of it is green
Old Aug 12, 2005 | 08:28 AM
Default Re: (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">... Left side of dashboard in vicinity of fusebox. It's behind the cruise control module, I believe it has a five wire connector. The bottom of it is green</TD></TR></TABLE>
dont mean tyo step on ur toes ole buddy but it has 7 wires going to it and looking from under it it is kind of,brownish/rusty color.......u need to remove cruise control box or u cannot really see it 2 10mm bolts
Old Aug 12, 2005 | 08:32 AM
u know what if i remember corerctly i thing starting 94 they moved the relay to the rt side of steering column but am not 100% sure ..
Old Aug 12, 2005 | 09:16 AM
P_Adams's Avatar
Default Re: (deserthonda)
I've modified my notes.... Lol
P
Old Aug 15, 2005 | 12:45 PM
aws140's Avatar
could the fuel filter be my problem? i was told thats probably what it was, but i always thought if it was going out the car would "skip" at high rpms and i took it to up in the rpms and check and it didnt do anything.
Old Aug 15, 2005 | 02:33 PM
P_Adams's Avatar
Noooo, Believe DH and myself. It's the main relay.
A clogged fuel filter will effect high speed driving way before it would effect starting.
P
YeuEmMaiMai's Avatar
if it is your main relay you can test it by tapping it. If the car starts after you tap it, replace it. I have troubleshoot many a honda by doing that......... You can also take it apart and re-solder all of the joints and it will fix the issue most of the time.
Old Aug 15, 2005 | 03:13 PM
aws140's Avatar
so its on the right side of the steering wheel, brownish colored, with 7 wires going into it?
Old Aug 20, 2005 | 01:48 AM
i_kick_turtles's Avatar
same thing happened to me its the main relay.
Old Aug 29, 2005 | 11:09 AM
DirtyBirdJR's Avatar
Default Re: (I R Tylor)
what about a 98 4cyl., my friends car is doing the same thing where would the relay be in this car
harleyjohn
May 9, 2015 03:04 PM
knightnam
Nov 12, 2005 06:26 PM
thegrenone
Nov 4, 2005 05:52 PM
livelife46290
Aug 26, 2004 07:07 PM
MADEinJAPAN
Sep 27, 2003 09:36 PM
