are these pipes good for a B-serise log manifold ?
Old Aug 12, 2005 | 03:18 AM
RACEPAK's Avatar
Default are these pipes good for a B-serise log manifold ?
hello everybody...
i got these pipes today for very cheap.
are these any good to make a B-serise log manifold?
2" is the outer diamention...
best regards moshik galimidi
Old Aug 12, 2005 | 04:44 AM
cua0's Avatar
they'll work. you might have some clearance issues with the bolts though.
set it up on the flange and see how they clear the holes, that would be the best way.
also you are only going to need 2 of those 90's and 2 T's if you are doing the classic log style manifold.
if you got them cheap enough why not get some more and do a top mount or ramhorn or some other kind of equal length manifold or something with a better collector than the classic log?
Old Aug 12, 2005 | 04:56 AM
RACEPAK's Avatar
Default Re: (cua0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cua0 &raquo;</TD></TR><TR><TD CLASS="quote">they'll work. you might have some clearance issues with the bolts though.
im not to worried about the bolt clearnce, im gonna crush the side of the pipe that will be welded on the flange so thay will be matched.
ramhorn and top mount are to complicated for me....
Old Aug 12, 2005 | 12:53 PM
project dc2's Avatar
Default Re: are these pipes good for a B-serise log manifold ? (RACEPAK)
if u're gonna use those i'd highly recommend bracing it . its not too thick. its thicker than needed for day a downpipe but for a manifold i'd be weary on using it .
Old Aug 12, 2005 | 05:14 PM
AceRaceParts's Avatar
Default Re: are these pipes good for a B-serise log manifold ? (project dc2)
Just for reference sake...
1.5" sch10 pipe = 1.9" OD x .109" wall (1.682" ID)
1.5" sch40 pipe = 1.9" OD x .145" wall (1.610" ID)
Your material = 2" OD x .065" wall (1.87" ID)
The difference in wall thickness is either .044" or .080"...keep this in mind
civic-r11
Oct 9, 2009 04:06 PM
JDMB20TDA
Apr 15, 2006 08:57 AM
jbell
Feb 6, 2006 01:12 PM
RACEPAK
Nov 27, 2005 11:13 AM
usdmcivic94
Jan 22, 2005 12:45 PM
