will a dc header from a 92-95 civic fit in my 90 civic?
will a dc header from a 92-95 civic fit in my 90 civic?it is a sohc zc as far as the motor i know the fitment is right but as far as the cat positioning i am not sure and the length also.anyone know
It should i would port some of the header out with a dremel just to get some better flow. I think the cat position should be the same.
it should be fine if the cat sits to high and rubs against the shift linkage just get some bigger rubber hangers or if it hangs to low get some smaller ones other than that it should fit fine. I know my 4-2-1 on my zc kinda rubs against my shift linkage a little bit but other than that it fits fine.
Unfortunately we did have to take it off its not to bad you can try loosening the two nuts from the front that hold i think the two bars in the front and loosen one side and you might get enough rooom to squeeze it in.
I think you can squeeze it in there w/o removing the crossmember as long as it's a 2 piece header.
*Edit - I think I removed the radiator to make that possible. Pick your poison
sherdog9
Jul 7, 2007 11:04 AM
