Do i use my stock ac lines?
Old Aug 11, 2005 | 11:19 PM
BlKdOutEk's Avatar
Default Do i use my stock ac lines?
I am dropping a 95' b18b into my 96' ek hatch. My hatch has the stock motor still in it with ac. Will the ac work with my stock lines or do i have to use the ac lines from the b18b. Please help me out guys
Old Aug 11, 2005 | 11:28 PM
eg6sir-s's Avatar
Default Re: Do i use my stock ac lines? (BlKdOutEk)
you use your original lines for ac.
Old Aug 12, 2005 | 12:51 AM
nocturnaldragon's Avatar
Your stock stuff is what you use.
Old Aug 12, 2005 | 08:00 AM
BlKdOutEk's Avatar
Default Re: Do i use my stock ac lines? (nocturnaldragon)
ok thank you
Old Aug 12, 2005 | 08:04 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
The only thing you might have to change is the AC compressor bracket. Im not sure a SOHC compresser will fit on that.
Old Aug 12, 2005 | 09:54 AM
kleanlscivic's Avatar
ok you use ur stock ac lines, you have to either buy a 94 del sol vtec ac bracket (p54, b16 engine), or i have also heard about people using the crv b20 motor ac compresser bracket. you should be about to find a p54 bracket on here easily. and you will also need a tensior assembly for the serp. belt
delsoleg2
Mar 16, 2011 01:46 AM
lPat
Aug 21, 2007 03:14 PM
rezneffix
May 16, 2007 09:54 PM
db8gsr_teg
Feb 22, 2006 07:25 AM
