Rear Torsion Mount Hole STRIPPED after Clutch install!!!
Old Aug 11, 2005 | 08:49 PM
EddieHatchBlack's Avatar
Default Rear Torsion Mount Hole STRIPPED after Clutch install!!!
So just when I thought I would get no trouble doing a clutch/flywheel install, I started hurrying near the end (and sun going down), now I caused a greater problem. (Damn air-tools).
I stripped the top of the two 19mm bolt holes on the engine side of the rear torsion mount. The tranny side 19 is perfectly fine. I was searching and heard of Helicoil and I have no idea what that is and if it's big enough for a 19mm. I was told to get a tap and die set, but I don't know if drilling it out to 21mm is good idea?
Any suggestions on fixing this problem? I was thinking of taking the whole rear torsion mount out and seeing if I can get the 19mm bolt to go inside if only one thread is stripped? I don't know. I even heard it's okay as long as one of those 2 are tightened real well, but I don't want to risk that.
Thanks,
Eddie.
Old Aug 11, 2005 | 10:59 PM
Default Re: Rear Torsion Mount Hole STRIPPED after Clutch install!!! (EddieHatchBlack)
Bump?
Old Aug 11, 2005 | 11:36 PM
Luserkid's Avatar
I got a guy that could fix that for you. Depending on how bad it is it wont take long. His in Gardena. Let me know if you want his info.
Old Aug 12, 2005 | 12:10 AM
Default Re: Rear Torsion Mount Hole STRIPPED after Clutch install!!! (Luserkid)
Well I don't think it's that bad, and for 1 bolt, I don't think taking it to a guy is worth. Also, I wouldn't know how to. Thank you though, I will keep it in mind just in case this problem escalates.
Anyone else have any other info or suggestions on tap-and-die or helicoil things? Hopefully taking off the mount while reveal a problem that isn't that bad.
Eddie.
Old Aug 12, 2005 | 12:34 AM
IT'S ME DAVID's Avatar
NooB
it should be fine
Old Aug 12, 2005 | 07:01 PM
Default Re: Rear Torsion Mount Hole STRIPPED after Clutch install!!! (BLACK EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">it should be fine</TD></TR></TABLE>
Yeah I got that whole bracket in and the car is completely done. Only thing is I lost a 10mm bolt that attaches the flywheel cover to the tranny. Is this even needed? I hear of many people who don't even have a flywheel cover. We'll see what happens.
8VEYBEYB
12
Aug 25, 2009 11:01 AM
skarpenz
Nov 20, 2008 11:33 AM
Blue-Civic-Hybrid
Jan 25, 2005 05:44 PM
travis
Aug 28, 2004 09:53 PM
