what sensor is this? accidently broke off!
Old Aug 11, 2005 | 08:35 PM
dxhatch92's Avatar
Default what sensor is this? accidently broke off!
this sensor broke off on my 1.5 dx motor and i dont know what it is. would it be alright if i left it off because it doesnt seem to be giving me any codes.
Old Aug 11, 2005 | 09:26 PM
mike93eh
Guest
Posts: n/a
pressure regulator.
what do youj mean it broke off? its prolly fine.
Old Aug 11, 2005 | 09:29 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (mike93eh)
Pressure regulator??
No, thats the EVAP Purge Solenoid. It vents the gas vapors into your intake manifold. Not necessarilly needed, its for emissions, but you will have to vent the gas into open air... Just pick up a new one froma junk yard.
Old Aug 11, 2005 | 09:34 PM
SOHC4life 96's Avatar
That's your flux capacitor, it helps activate the VTEC dippitydoo......you say you broke it off? Oh man sorry, cause you're fucke.
No, really its your evap.......or "if you dont know what it is it has to do with smog dont touch it" sensor.
Old Aug 11, 2005 | 09:35 PM
khmboostedeh2's Avatar
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote"> the EVAP Purge Solenoid.</TD></TR></TABLE>
as long as your car is obd1, which i assume it to be, you shouldnt throw a code from it being disconnected.
Old Aug 11, 2005 | 09:41 PM
GdmLaz's Avatar
it doesn't matter if is broken off as long as you have a hose connected to it you should be k if not ur gonna have a pretty big vacuum leak
Old Aug 11, 2005 | 10:01 PM
CHiNkStEr's Avatar
i would trust the guy with the most post on what that part is.
Old Aug 11, 2005 | 10:56 PM
built562's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">pressure regulator.
what do youj mean it broke off? its prolly fine.</TD></TR></TABLE>
holy crap, do you even know what you are looking at bro.
that is the evap purge solenoid, it hooks up to the number 7 emissions hose from the charcol canister. if your car is OBDI you will not throw a check engine light as stated above. you can un hook it and unplug it and nothing will happen if your car is obdI
Old Aug 11, 2005 | 11:17 PM
handa's Avatar
Default Re: (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">
that is the evap purge solenoid, it hooks up to the number 7 emissions hose from the charcol canister. if your car is OBDI you will not throw a check engine light as stated above. you can un hook it and unplug it and nothing will happen if your car is obdI</TD></TR></TABLE>
you don't need that solenoid....i don't have one. but if your state requires for smog or something, you'll need it.
Old Aug 11, 2005 | 11:30 PM
SRCivic97's Avatar
Default Re: (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">That's your flux capacitor, it helps activate the VTEC </TD></TR></TABLE>
The Delorian had Vtec!! Well...It was DOHC anyways
Old Aug 12, 2005 | 05:10 PM
WayQuiz's Avatar
Default Re: (SRCivic97)
any gains or losses with that thing still connected?
Old Aug 12, 2005 | 05:24 PM
old man neri's Avatar
Default Re: (wayquiz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wayquiz &raquo;</TD></TR><TR><TD CLASS="quote">any gains or losses with that thing still connected?</TD></TR></TABLE>
loss: killing the air we breathe for no reason.
leave it hooked in, you feel better that you helped the environment.
Old Aug 12, 2005 | 11:54 PM
dxhatch92's Avatar
Default Re: (old man neri)
yea the top part broke while dropping in the motor. i opend it up and its like a foam filter inside. will i be able to pass emissions with it being broke off? maybe i should superglue it back on or something
sony224422
Jun 17, 2011 05:08 PM
xelloss
Oct 22, 2008 12:12 PM
-JSpecEk*9-
22
Jun 8, 2006 02:26 PM
djwest24
Mar 21, 2004 09:24 AM
