Tranny Problem, Input Shaft gets hard to spin sometimes
Old Aug 11, 2005 | 08:24 PM
DEMNTD1's Avatar
Default Tranny Problem, Input Shaft gets hard to spin sometimes
Need help. Just put back together a 4.785 tranny with Cusco LSD. Now without the housing on, the input shaft spins freely and easily. Once I put on the housing, input shafts spins freely, but then will get hard to spin.
It seems that when the Ring Brake Stopper #9 on the diagram is held in place the input shaft spins freely for a bit then gets hard to spin.
What is the problem? Do I need to change the #10 tapper cone and #17 bearing?
Old Aug 12, 2005 | 11:12 AM
Rocket's Avatar
Default Re: Tranny Problem, Input Shaft gets hard to spin sometimes (DEMNTD1)
I would put only the diff in case halves (no sealant) and tighten up a lil like 10lbs and see how freely the diff spins.
I always do this when installing a diff that was not original to the tranny.
Hopes this helps you out.
B18C Turbo
Oct 3, 2006 02:11 PM
Circuit Star-29
Mar 6, 2006 12:09 AM
