Tranny probs...Input shaft spins...DIFF does not...
Old Mar 5, 2006 | 10:53 PM
Circuit Star-29's Avatar
Default Tranny probs...Input shaft spins...DIFF does not...
Cut to the chase:
Input shaft spins but after about 3-4 rotations the diff stops spinning...any ideas? Just trying to get an idea on what IT MIGHT BE... This tranny was GOOD before I took it apart.
Thanks guys.
I figure you guys prolly break a good number of trannies and might know what the deal is...
Old Mar 5, 2006 | 11:25 PM
Gearspeed-Performance's Avatar
Default Re: Tranny probs...Input shaft spins...DIFF does not... (Circuit Star-29)
Get it open and make sure that everything is set back the way it is suppossed to be...double check...Did you make any changes to the differential?...If so recheck clearance and make sure that it is not rubbing on anything.
Old Mar 5, 2006 | 11:27 PM
Default Re: Tranny probs...Input shaft spins...DIFF does not... (GearSpeedEF7)
WOuld shims be the problem here? I just can't imagine that the input shaft would fail to rotate the diff if its a shim issue.
Old Mar 5, 2006 | 11:30 PM
If the differential is too tight...it won't spin
Old Mar 6, 2006 | 12:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearSpeedEF7 &raquo;</TD></TR><TR><TD CLASS="quote">If the differential is too tight...it won't spin</TD></TR></TABLE>
I understand where you are going... But the input shaft still spins......doesn't this seem odd?
Old Mar 6, 2006 | 12:09 AM
Something may be off or not set straight...that may cause a slip then stick type of effect.
94 EG GSR
Aug 14, 2009 09:28 AM
DEMNTD1
Aug 12, 2005 11:12 AM
efcivic757
Mar 10, 2005 10:06 PM
