Precision 1000cc injector fitment?
Old Aug 11, 2005 | 07:18 PM
Pikachu's Avatar
Default Precision 1000cc injector fitment?
I've been trying to get these on my car but it looks like the insulator, the black ring piece is too small making it really loose when you put the injector on. It's the piece that goes right onto the intake manifold. It's a piece of rubber. It's a stock fuel rail and stock intake manifold. Unfortunately this is going to cause me to miss Honda-day this weekend.
Is there someone with experience that can advise on this? Thanks in advance!
Old Aug 11, 2005 | 07:39 PM
PrecisionH23a's Avatar
Default Re: Precision 1000cc injector fitment? (Pikachu)
You have to open up the o-rings. Dremel's work nicely. You'll probably have to mod it a bit for everything to work out.
Old Aug 11, 2005 | 07:42 PM
Pikachu's Avatar
It's too small not too big. If it was too big, I'd do that in a heartbeat.
Old Aug 11, 2005 | 08:00 PM
Default Re: (Pikachu)
Every Precision injector I have seen has been too big and the O-ring had to be modified.
What injector were you running previously?
Old Aug 12, 2005 | 03:11 AM
Pikachu's Avatar
RC 550's and they fit perfectly.
Old Aug 12, 2005 | 05:12 AM
spoolinlude's Avatar
I live under a rock
mine fit fine, i use the stock honda rings.........
Old Aug 12, 2005 | 06:10 AM
Pikachu's Avatar
They fit? Didn't have an extra set of those so if they indeed do, I'll try to get those. Thanks man!
Old Aug 12, 2005 | 01:19 PM
fastlude69's Avatar
mine fit fine too
Old Aug 12, 2005 | 01:20 PM
john d
Guest
Posts: n/a
Default Re: (fastlude69)
mine fit fine
Old Aug 12, 2005 | 03:29 PM
fastludeh22's Avatar
Default Re: (spoolinlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">mine fit fine, i use the stock honda rings.........</TD></TR></TABLE>
exactly... i have the 160# ones. i had to use longer studs to hold the fuel rail down, and make it real tight
Old Aug 13, 2005 | 04:33 AM
clemsoncb7's Avatar
Default Re: (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">exactly... i have the 160# ones. i had to use longer studs to hold the fuel rail down, and make it real tight</TD></TR></TABLE>
How did you get longer studs in there? I thought they were non-replacable.
Old Aug 13, 2005 | 12:04 PM
Default Re: (maxvtec7500)
they come out using the double nut trick...but truth is i didnt do that, just what i was supposed to do.
story goes like this, i had to get car tuned at 10 am. it was 11 pm the night before and i was finishing up. i forgot to buy the studs. i took the fuel rail and grinded down the nipples that the stud went though flat with the fuel rail. i was able to use the factory stuff that way.
Old Aug 13, 2005 | 01:31 PM
I am using the AEM fuel rail with GE intake manifold. You guys don't need to use longer studs...
Just shorten part number 7. I use a bench grinder to do so. After I check to make sure it's all even with a dial gauge caliper (i'm ****). Afterwards there was still a little fitment issues so I invested in a few washers to help me out. It's not as hard as you guys are making it out.
Old Aug 13, 2005 | 01:55 PM
Default Re: (PrecisionH23a)
at the time, i was using stock itm and stock fuel rail. part #7 wasn't an issue on mine. the injectors were just physically bigger, causing so you couldn't get a nut on the end of the stud
FrOsTwHiTeDC4
Jan 2, 2007 07:44 PM
Anti-Drama Queens
Apr 6, 2006 05:20 AM
b18c1wes
Dec 10, 2004 09:59 PM
djnikko
Oct 13, 2003 06:58 PM
Mikey3000
Mar 19, 2002 11:21 AM
