Timing HELP!!!
Old Aug 11, 2005 | 06:45 PM
TMTNG9's Avatar
Default Timing HELP!!!
I just recently having problems with my First Gen B16A. I think it has to do with my timing, my car is back firing and it misses every once in a while. V-tec got quiet and sometimes I don't feel it in first. I got a timing light on it and for some reason it reads 30+ I tried messing around with it but I couldn't get it to 14 degrees. The only code I have on my car is 23 which is a knock sensor but it keeps going away this is the second time the CEL came on. Can anyone help PLEASE!!!! Thanks
Old Aug 11, 2005 | 07:15 PM
onepoint6i's Avatar
Default Re: Timing HELP!!! (TMTNG9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TMTNG9 &raquo;</TD></TR><TR><TD CLASS="quote">I just recently having problems with my First Gen B16A. I think it has to do with my timing, my car is back firing and it misses every once in a while. V-tec got quiet and sometimes I don't feel it in first. I got a timing light on it and for some reason it reads 30+ I tried messing around with it but I couldn't get it to 14 degrees. The only code I have on my car is 23 which is a knock sensor but it keeps going away this is the second time the CEL came on. Can anyone help PLEASE!!!! Thanks</TD></TR></TABLE>
check your cam timing and belt tension...
Old Aug 11, 2005 | 07:24 PM
boosted k20's Avatar
Default Re: Timing HELP!!! (1.6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i &raquo;</TD></TR><TR><TD CLASS="quote">
check your cam timing and belt tension...</TD></TR></TABLE>
set the motor to TDC and check the timing. sounds like u might have jumped a teeth on the cam gears
Old Aug 14, 2005 | 05:23 PM
TMTNG9's Avatar
I've check that but it looks like it's right on. By the way do you know the part number to the right timing belt right now I have the P2T belt so I don't know if that the right one. Thanks
Old Aug 15, 2005 | 07:14 PM
92civicsib18c5's Avatar
both cam arrow up,numer 1 cylinder tdc and make sure you don't have a cross plug wire.
jz2518
Jul 8, 2013 07:09 AM
.BigSexy
Oct 19, 2006 05:07 PM
boostin4door
Jul 27, 2006 06:38 PM
TMTNG9
Aug 14, 2005 05:21 PM
hachement
12
Sep 22, 2004 06:17 AM
