Auto to 5spd
Hey
i have a 94 hatch thats auto
and i was wondering what all do i need to make it 5spd, how much youd think it would all cost and if anyone has photos that would help too
. And is it hard to do or not
thanks
. And is it hard to do or notthanks
Parts Necessary for a Civic or Del Sol Auto to Manual Transmission Conversion:
-Manual Transmission
-Clutch/Pressure Plate/Throw Out Bearing (your average clutch kit will do the trick)
-SOHC Flywheel w/bolts
-Civic SOHC Shift Linkage
-Shifter (civic or del sol stock shifter will work fine)
-Shift **** (see comment from above)
-Clutch Fluid Resevoir
-Clutch Master Cylinder (Civic, Integra, or Del Sol)
-Clutch Slave Cylinder (Civic Integra, or Cel Sol
-Clutch Hard Lines (Civic, Del Sol, or Intgra should all work, or custom bent or braided steel lines..)
-Clutch/Brake Pedal Assembly (gas pedal doesn't need to be changed)
-Auto-Manual Conversion Mount (jdmshit.com has it for $110 shipped)
-Manual p28 ECU or Convert an Auto p28(Search for this)
-Manual Throttle Cable (I am not sure if this is necessary.. anyone?)
-Lower Manual Transmission Mount (OEM)
Wiring Directions Found Here:
http://brokenlimits.com/howto/...l.htm
It isn't hard if you have any sort of mechanical ability.. as well as a little electrical ability (not much wiring to be done)...
Good Luck.. Prices vary. look for good deals
94EGcoupeh22a
Dec 31, 2006 01:15 AM
uszcrx
Aug 13, 2006 04:34 PM
Boarder03
Mar 30, 2006 07:06 PM
Pocket_Rocket
Aug 12, 2005 04:40 PM
metrocedes
Aug 11, 2005 07:52 AM
