Installed DA steering wheel... how to get horn to work?
Old Aug 11, 2005 | 04:08 PM
Nisif's Avatar
Default Installed DA steering wheel... how to get horn to work?
Looking for anyone else that has a 93 integra steering wheel (4 spoke style) in their EF. The horn contacts are different, wondering if anyone has done this swap and has the horn working and how you did it. Btw, I detached the cruise control box, but left the blue/red wire hooked up (assuming this is the wire for the horn switch).
Old Aug 11, 2005 | 09:29 PM
Nisif's Avatar
Default Re: Installed DA steering wheel... how to get horn to work? (Nisif)
bump
Old Aug 12, 2005 | 08:31 AM
Nisif's Avatar
Cmon, I know some of you guys have the DA wheel....bump
Old Aug 12, 2005 | 09:44 PM
EF_9's Avatar
i have a DA steering wheel
horn works but...
stop turn steering wheel to the right and hit your right signals hahaha then itll work
because i never got mines to work
Old Aug 12, 2005 | 11:01 PM
silentdork818's Avatar
Default Re: (EF_9)
Just get a non-cruise control steering wheel. They came in the RS model Integras. Itll be way easier than trying to get your cruise control steering wheel to work.
Old Aug 13, 2005 | 11:04 PM
Nisif's Avatar
Default Re: (ef four door)
Too late, I already bought the wheel that came off of a 93 Gs
Old Nov 19, 2011 | 11:24 AM
kenji801's Avatar
anybody have a write up about this i need to know too..
Old Nov 19, 2011 | 11:59 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Nice, you revived an old pointless thread...
Have you tried pushing on the center of the steering wheel?
Old Nov 20, 2011 | 08:57 AM
kenji801's Avatar
yes but the horn is on a crx and i wanted to know how to wire it up.
Old Nov 20, 2011 | 11:21 AM
floodx4's Avatar
That was a little harsh, even for you, N3va :-)
On topic...
First this is assumption, as I don't have an Integra wheel, but I would assume that the horn works like all (most) any other horn. It is just a Normally Open switch that when closed, completes the circuit to sound the horn. So I would start by finding the 2 wires that are for that switch, then graft them in to the CRX's horn wiring.
Worst case, you could run a hot wire to the wheel contact, then a switched wire back to the horn, bypassing the Rex's wiring alltogether.
Old Nov 22, 2011 | 01:26 AM
Nisif's Avatar
On topic...
Back from the dead...to this day I still have the 93 da wheel w/ the cruise control buttons on my ef. I use the cc resume button as the horn button. IIRC, I ran a wire from the metal ring for the horn contact and wired it to the cc button. Pretty sure I had to bend one of the contacts that touches the metal ring and do some other minor altercations for it to work. Although 6 years later and I've had no problems with it...keeps my middle finger on the wheel
Neptronix
Jul 8, 2008 01:13 PM
bong_671
Feb 25, 2006 06:34 AM
cyrilic
Feb 5, 2004 03:08 PM
aaaallll04
Jul 19, 2003 11:25 AM
beeboyee
Apr 30, 2002 11:53 PM
