Ek w/B16a2 , what all do I need...
Old Aug 11, 2005 | 02:41 PM
lhd dc2's Avatar
Default Ek w/B16a2 , what all do I need...
to get the air condition to work? i.e. what a/c bracket, and compressor and what ever else I need. Any help would be appreciated. TIA
Old Aug 11, 2005 | 02:49 PM
b 1 6 a 2's Avatar
You have a few options.
You can retain the D compressor, if you have one, and bolt the compressor using 2 bolts, since the bolt pattern is offset using the D16y8 compressor. It sounds risky, but thats what i have done at the moment and it's been great for the past 9 months. It also retains your freon using this method. I have a B16 compressor for backup and I'll probably swap for that one when i run out of freon with this setup.
You can also get a b16 del sol ac bracket or one from a crv. The crv will probably be cheaper.
Last is get the compressor from that engine and the ac lines to make it like orignal.
Old Aug 11, 2005 | 02:58 PM
lhd dc2's Avatar
Default Re: ([civic])
Okay so,
D series compressor and bracket using 2 bolts on the bracket
or
Del Sol brackets along with the B compressor and A/C lines from Si or De sol?
Thanks for the quick response.
Old Aug 11, 2005 | 04:10 PM
b 1 6 a 2's Avatar
Default Re: (DBtwo)
Actually, its a d-series compessor on a b16 block, mounted with only 2 bolts. The other 2 will not match up. I can try to take a picture when I get the chance.
jdmjin
Jul 28, 2013 04:46 PM
crazyguy
Aug 6, 2007 08:22 PM
EJ8VTEC
May 28, 2005 07:39 PM
TypeR II
Jul 13, 2004 08:58 AM
LXguy
Feb 6, 2002 12:00 PM
