HELP!!! Knuckle ABS and non ABS
I need a knuckle for my 93 Prelude S wich is non ABS,
I'm going to order parts and can only get ABS one.
Will it fit ?
There are 2 different part# for ABS and non ABS knuckle but I don' t know what' s the difference between the 2 parts.
also, do I need the bearing hub bearing when I change the knuckle ?
Modified by Siegfried at 10:26 PM 8/11/2005
Modified by Siegfried at 6:06 AM 8/12/2005
Will it fit ?
I went through this once before, the S models, have the bosses on the spindle, but they are not drilled or tapped, other than that you dont need anything different, you can use an abs spindle but it will have a few more bolt holes, I have a prelude s model passenger side spindle here if ya want it ill sell it cheap
JRTegman987
Dec 2, 2023 04:16 AM
2camsaam
Oct 3, 2003 07:29 AM
