THe wierdest sh** ever
Old Aug 11, 2005 | 10:40 AM
wtaylor70's Avatar
Default THe wierdest sh** ever
I have a 93 Accord EX
So I just got my transmission replaced and now the light which tells you which gear your in ex. P R N D4 D3 2 1 starts to flash around D4 whenever I drive. Also my speedometer went out and my check engine light is now on. I also switched to 15w 40 oil coiuld that affect it?
Old Aug 11, 2005 | 10:42 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: THe wierdest sh** ever (wtaylor70)
Oil has no affect
I believe the Blinking D4 is similar to your CEL.... gives error codes for the tranny.
As far as your speedo, could be several things.... VSS, bad connection in harness.....
Old Aug 11, 2005 | 10:43 AM
sj993's Avatar
Since your speedometer went out and the D4 light is blinking I would say your VSS (Vehicle Speed Sensor) or the connection is bad. Take it back to where you had the tranny replaced and have them look at it.
I don't think the oil is the problem.
Old Aug 11, 2005 | 10:45 AM
wtaylor70's Avatar
What about the check engine light is that something I should worry about?
213374U's Avatar
0x5359-0055
Community Builder
Default Re: THe wierdest sh** ever (sj993)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sj993 &raquo;</TD></TR><TR><TD CLASS="quote"> VSS (Vehicle Speed Sensor) </TD></TR></TABLE>
I thought it was Variable Speed Sensor.... might be wrong though
Old Aug 11, 2005 | 10:46 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: THe wierdest sh** ever (Vt4cPwn35)
You'll need to pull the CEL codes to see what's wrong
Old Aug 11, 2005 | 11:14 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">I thought it was Variable Speed Sensor.... might be wrong though </TD></TR></TABLE>
yep you're right, you're wrong.
Old Aug 11, 2005 | 11:33 AM
CWestAccord's Avatar
Default Re: THe wierdest sh** ever (notoriousB)
check the code, to see what's up.
BTW, 15w40 is used most commonly by Diesel pickup trucks. EXTREMELY heavy weight. I'd recommend switching back to 10w30, or 5w30.
Old Aug 11, 2005 | 11:49 AM
se7enofseven's Avatar
Default Re: THe wierdest sh** ever (CWestAccord)
ditto
10w-40 is the thickest i would run and only a synthetic or synthetic blen
Old Aug 11, 2005 | 12:06 PM
wtaylor70's Avatar
Default Re: THe wierdest sh** ever (se7enofseven)
I switched because I was having issues with a flickering oil light after driving for about 10-15 minutes... Will 15w 40 hurt my engine?
Old Aug 11, 2005 | 12:41 PM
P_Adams's Avatar
In the summer months, NO 15w x 40 is ok.
It could cause a slow crank condition in cold weather (however), and in Portland (whatever state) it does get cold!!!
P
Old Aug 11, 2005 | 12:49 PM
wtaylor70's Avatar
Default Re: THe wierdest sh** ever (P_Adams)
Portland, Oregon it does get cold but it's still summer. So that would not cause any of the check engine light problems....
kevodean
Feb 22, 2009 06:51 PM
jdub20tx
Nov 2, 2008 05:06 PM
nickhans
Feb 14, 2006 01:10 PM
J-Ra
Sep 12, 2004 09:49 AM
