Is my timing off?
Old Aug 11, 2005 | 08:29 AM
Power Rev Racing's Avatar
Default Is my timing off?
I have the crank at top dead center, and this is what the cam gear is showing. If this is off, please tell me where to line up the cam.
1991 Civic Std D15B1
Old Aug 11, 2005 | 08:32 AM
No-Gi's Avatar
Default Re: Is my timing off? (Power Rev Racing)
Deff off from what I see. Since its a d15 it needs to be flat. It it were a d16a you need to line it up using the bottem left pointer and the other mark.
Its kinda in between both. Someone fucked up before.
Old Aug 11, 2005 | 10:22 AM
CBURKE's Avatar
Yeah it off pretty bad.
Old Aug 11, 2005 | 10:58 AM
trrbl1bmx's Avatar
in the picture the two lines should line up with the top of the head, ( with the valve cover off ) if not that you are off. and most importantly make SURE its at TDC!
Old Aug 12, 2005 | 01:27 AM
peiku's Avatar
Default Re: (ilovemyef9)
just match the line (yellow circle) with the pointer (green circle).
Old Aug 12, 2005 | 05:48 AM
.Unknown.'s Avatar
Default Re: (peiku)
Are you sure you lined it up right on the crank? Remember on the crank you'll see
| | | and then spaced out | Double check it.
It should be lined up with the Middle Slash.
Old Aug 12, 2005 | 06:48 AM
jlicrx's Avatar
Default Re: (.Unknown.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Unknown. &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you lined it up right on the crank? Remember on the crank you'll see
It should be lined up with the Middle Slash.</TD></TR></TABLE>
TDC is the single mark by itself off to the right of the 3 ignition timing marks
Modified by jlicrx at 9:23 AM 8/12/2005
Old Aug 12, 2005 | 11:41 AM
peiku's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
jlicrx is right. the middle line of the three marks should be red. the single one, off to the right, should be white. it might be hard to see if its dirty.
Old Aug 14, 2005 | 08:18 PM
.Unknown.'s Avatar
Default Re: (peiku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku &raquo;</TD></TR><TR><TD CLASS="quote">jlicrx is right. the middle line of the three marks should be red. the single one, off to the right, should be white. it might be hard to see if its dirty.</TD></TR></TABLE>
So we go based off the RED one? Correct me if I'm Wrong..
Old Aug 15, 2005 | 04:45 AM
peiku's Avatar
use the white one.
EG_Warped
24
May 25, 2011 03:55 PM
wambus
Honda Civic (2001 - 2005)
Feb 22, 2010 08:05 PM
lv6l
Nov 17, 2005 12:33 PM
Kirt Porter
Oct 8, 2004 09:10 PM
Tommy_Gunns
Aug 23, 2002 03:07 PM
