Is this crankshaft acceptable to use in my build?
Old Aug 11, 2005 | 08:17 AM
d16dcoe45's Avatar
Default Is this crankshaft acceptable to use in my build?
Hey guys--I figured I would ask this question in the all motor & FI forums, because alot of knowledgable people frequent these forums. My question is I spun a bearing in my motor a while ago (rod bearing) and it chewed up the crank a little--enough to where I feel it isn't worth it to get the crank repaired. I had another (d16) motor sitting around with about 150k on it. The journals of the crank look acceptable to use, but where the rear main seal rides, there is a groove in the crank--from where dirt must have gotten under the seal and slowly dug a groove into the crank. Now I now the crank will run fine, but, when I put a new seal on, will the groove on the crank ruin the new seal? Any help would be greatly appreciated---pics below (see what I mean by "groove"?) I know the pics aren't very good--but its the part where the flywheel bolt holes are located and where the rear main seal rides on--
[IMG][/IMG]
Old Aug 11, 2005 | 11:25 AM
d16dcoe45's Avatar
Default Re: Is this crankshaft acceptable to use in my build? (d16dcoe45)
Just fyi--if any one else has this problem--a guy in the FI forum told me about SKF Speedi-Sleeves--they are very thin sleeves made of a durable material that fit over the grooved part of the crank--I don't know exactly how they are installed, but they let you use the same sized seal and will save the crank!!
Old Aug 11, 2005 | 01:32 PM
d16dcoe45's Avatar
I have gotten about 22 replies in the FI forum--no one has an opinion here?
Z0831xiz
Apr 26, 2015 03:56 PM
mySIisLOVE
Feb 25, 2008 11:54 AM
DanishR
Oct 7, 2007 07:41 PM
d16dcoe45
Aug 12, 2005 08:15 AM
JDcompman
May 14, 2004 10:49 AM
