Ecu codes help me out fellas...
Old Aug 11, 2005 | 07:41 AM
88EFhatch's Avatar
Default Ecu codes help me out fellas...
My car is throwing some codes but I have no idea how to read them. Its an 88 dx hatch and I recently put in a new radiator, the codes are #6 and #7 does anybody know what are they?. Thanks in advance.
Old Aug 11, 2005 | 08:25 AM
88EFhatch's Avatar
Default Re: Ecu codes help me out fellas... (88EFhatch)
Bump anyone??
Old Aug 11, 2005 | 08:44 AM
crx90rcr's Avatar
6 is water temp sensor. i have no clue were that is but then the code 7 is tps wich is on ur throttle bodyt and is the plug in the back. if i were u id check to c if it is plugged in and then unbolt it and c if the tabs are in the rite notches. ull c what i meen when u open it up
Old Aug 11, 2005 | 08:47 AM
wrXtian's Avatar
Default Re: Ecu codes help me out fellas... (crx90rcr)
you can find a list of ecu codes here:
https://honda-tech.com/zerothread?id=468260
i found this in the faq's in this forum.. you can find a assload of information about almost anything in there.. try checking that out first when you get a problem.. about 90% of the time the faq's has covered it already.
https://honda-tech.com/zerothread?id=637661
good luck
Horseofcourse
Apr 28, 2008 07:44 PM
mawkiemarc
Apr 21, 2005 04:43 PM
Type R CivIc
Apr 6, 2005 11:57 PM
hondaZvic
Apr 21, 2004 06:26 PM
claytonsmith
Jan 26, 2004 09:53 AM
