Grinding noise, from wheel when turning?
I have a strange, metal/metal sounding griding/scraping/rubbing noise coming from the drivers front tire when turning. It mainly does it when turning right, but I can hear it faintly (I think) when turning left also. It happens even with quite small steering inputs (1/8th of a turn or less), but it is speed dependent.
I jacked the car, and cant feel any play in the wheel, checked the dustshield doesnt seem to be hitting anything. Any other ideas?
I have a track/autox event this sat/sun, think the car might survive?
I thought CVs were more of a "clicking" sound? THe car is under warranty but I took it to the dealer and they said they couldnt even have someone listen to it until next week they were so backed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cosworth »</TD></TR><TR><TD CLASS="quote">Get a reman. CV axle from autozone.</TD></TR></TABLE>
Nooooooooooooooooo! They are garbage - true story!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">Nooooooooooooooooo! They are garbage - true story!</TD></TR></TABLE>
Where's the story?
Where's the story?
Are you sure it's from the wheel? Does it happen at all speeds or high or low speed? I *think* when my wheel bearing started to go it made some odd noises when turning right before there was any noticeable play in the wheel
-jeff, who wishes he was still under warranty
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N »</TD></TR><TR><TD CLASS="quote">
Where's the story?</TD></TR></TABLE>
They are garbage. The end.
Yeah its from the wheel, or wheel area for sure. It happens at all speeds I think, I can even crawl around the parking lot at 2mph and its screeching away. I took it by the Honda dealer at lunch and the dude rode with me, he said he tought it was either a brake pad guide/warning indicator thingie (which I will look at tonite) or wheel bearing. The prob is they cant cover it under warranty b/c they are Honda not Acura (at least that is what he said).
Stephen, why not take it to Baranco? I know it's quite a drive, but TJ should be able to look after ya
I can prolly give u a ride back to the Northside if u need
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jetydosa »</TD></TR><TR><TD CLASS="quote"> brake pad guide/warning indicator thingie
man, didn't i tell you to check the pads last night?...slacker
bring it over to my place...i'll be in the garage anyway, playing with andrew's F125
They are garbage. The end. </TD></TR></TABLE>
That was way better than Goldilocks and The Three Bears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohtheguilt »</TD></TR><TR><TD CLASS="quote">i'll be in the garage anyway, playing with andrew's F125</TD></TR></TABLE>
F125 = weiner?
F125 = weiner?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dbl Ey! »</TD></TR><TR><TD CLASS="quote">
F125 = weiner? </TD></TR></TABLE>
sick-0
F125 = shifter kart
sick-0
F125 = shifter kart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">They are garbage. The end. </TD></TR></TABLE>
you can't say 'true story!' without a story before or after this statement.
f-ing we todd.
f-ing we todd.
If it occurs while turning, try checking to see if your inner fender lines have detached. Hungster had this problem where it would rub against the tire when turning or when the wheel was turned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohtheguilt »</TD></TR><TR><TD CLASS="quote">man, didn't i tell you to check the pads last night?...slacker
bring it over to my place...i'll be in the garage anyway, playing with andrew's F125</TD></TR></TABLE>
oh teh ghey! way to come in here and f--- up another thread!
chris - who thinks that whatever is wrong with stephen's car, is not as bad as what is wrong with nathan's head.
f-ing we todd.</TD></TR></TABLE>
I can say whatever I want - I'm speshul.
chris - who thinks that whatever is wrong with stephen's car, is not as bad as what is wrong with nathan's head.</TD></TR></TABLE>
now that is a "true story"
I have the same problem, been ignoring it for 9 months already
But oddly, mine only happens at very low speed, when i turn all the way. can't figure out what it is.
TokyoStatus
Nov 28, 2007 05:57 PM
