Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Looking for hard to find Eibach or Hyperco Springs ????
Old Aug 11, 2005 | 06:47 AM
FLATOUTRACING's Avatar
Default Looking for hard to find Eibach or Hyperco Springs ????
Autocross buddy is searching for the following:
2.5 by 7" 600 pound and 700 pound Hyperco or Eibach springs. Any advice on where to get them is appreciated.
Regards,
Jon
Old Aug 11, 2005 | 06:51 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Looking for hard to find Eibach or Hyperco Springs ???? (FLATOUTRACING)
edit: we do 7" 600lb, 650lb but not a 700lb. You'll need to go 6" or 8" for the 700lb spring in the Eibach line.
Modified by vtecvoodoo at 8:20 AM 8/11/2005
Old Aug 11, 2005 | 07:04 AM
GBRacing's Avatar
On my old CRX, I ran hypercoils which I bought from http://www.racecareng.com. I believe that can get just about every combination you could want.
Old Aug 11, 2005 | 07:13 AM
thawley's Avatar
Hypercoil does not list any 7" springs heavier than 450# in their current catalog. After that, you have to go with 6" or 8". I know Progress has a 550x7, but that's lower than you're asking for. You might try the metric spring manufacturers like H&R or KW and see if they've got anything close...
Old Aug 11, 2005 | 07:54 AM
hybridmoments's Avatar
Kofod.
Eshocks.com has the hypercoils in 8"
http://www.eshocks.com
this place has a big selection too
http://www.pitstopusa.com/shocks_springs.htm
Modified by hybridmoments at 9:06 AM 8/11/2005
Old Aug 11, 2005 | 08:12 AM
Default Re: Looking for hard to find Eibach or Hyperco Springs ???? (hybridmoments)
Steve,
The other Steve is looking for 7" s if possible. I've found a ton in 6" and 8" 's but no 7's so far.
Regards,
Jon
Old Aug 11, 2005 | 08:22 AM
can't he run an 8" and thread his GC sleeve down an inch? i know he isn't bottomed out on his sleeves cause he has to fit those big volks in the front
Old Aug 11, 2005 | 08:29 AM
He trying to save weight and he's worried about the higher springs rates (600/700) not compressing the spring far enough down and having to tinker with the ride height.
Regards,
Jon
Old Aug 11, 2005 | 08:41 AM
well he can get some custom springs made from INCONEL from here
http://www.dracospring.com/products.htm
Old Aug 11, 2005 | 08:50 AM
vtecvoodoo's Avatar
Future Texas Boy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoments &raquo;</TD></TR><TR><TD CLASS="quote">well he can get some custom springs made from INCONEL from here
http://www.dracospring.com/products.htm</TD></TR></TABLE>
...or I have a few 7" carbon fiber springs on my desk
Old Aug 11, 2005 | 09:12 AM
Jon.
Ground Controls online store has the 2.5" OD 7" length eibachs in 600lb, 650lb. no 700 though.
and in 6" length 700lb to 1000lb
from what eibach says on their website . i'd go with the 6" springs. not much less spring travel, and almost a pound lighter then the 7" springs .
6" length _______________spring travel __________weight in lbs
600lb ____________________3.43"________________ 2.35
700lb ____________________3.17__________________2.79
7" length_______________spring travel __________weight in lbs
600LB_____________________3.78 __________________3.21
650lb_____________________3.77__________________3. 31
8" length _______________spring travel __________weight in lbs
600lb ____________________4.29" __________________3.88
700lb ___________________4.20 __________________4.15
tell steve to put a ziptie tight around the Koni damper piston right at the damper body while sitting at ride height. then go blast really hard around some parking lots. then at ride height see how much the shock is travelling from how far the ziptie moved from the top of the damper body. it will travel even less then that when he moves from his current 425/400 to 700/600
Old Aug 11, 2005 | 08:26 PM
ewaugh's Avatar
Well, you heard it streight from Eibach. I'll call up Vogtland Monday and see what they make. It won't hurt for me to try H&R too.
I'll check the parts truck tomorrow night if I have a chance but it's possible that I have the 7" that they do make in stock.
Evan Waugh
R&H Performance Products
Old Aug 11, 2005 | 08:33 PM
.RJ's Avatar
.RJ
Jon - just go to 6" springs all the way around, easier that way
Old Aug 11, 2005 | 08:59 PM
phat-S's Avatar
Default Re: Looking for hard to find Eibach or Hyperco Springs ???? (.RJ)
Any way he can run a 2.25" spring?? I don't think that Hyperco makes that rate in 2.5" in less than an 8" length but I believe the world opens up for the 2.25" dia springs.
Old Aug 12, 2005 | 04:54 AM
Vitt1's Avatar
Default Re: Looking for hard to find Eibach or Hyperco Springs ???? (phat-S)
I called kingrat motorsports recently about 6" 600 lb. Hypercoils. He said that short springs with rates higher than around 450 lb. have to be a special order by the retailer, and he has to order a very large number of them for them to make them, that is why he doesn't carry them.
Old Aug 12, 2005 | 06:10 AM
Default Re: Looking for hard to find Eibach or Hyperco Springs ???? (Vitt1)
ground control has all the 6" springs on their online store.
this particular application they are using ground control sleeves on koni shocks, 2.25 is to small to fit over these sleeves .
Old Aug 12, 2005 | 07:09 AM
vtecvoodoo's Avatar
Future Texas Boy
We have a ton of the 6" stuff in stock from 400lbs to 1800lbs. GC orders it all the time and would most likely have it in stock.
Pothole987
Honda Civic (2001 - 2005)
Feb 21, 2010 10:53 AM
crxtuner0
Suspension & Brakes
Aug 14, 2009 10:02 PM
Booz
Aug 22, 2008 08:19 PM
implayaz9
Suspension & Brakes
Jan 6, 2006 07:20 PM
