What timing for 83mm B18C, LS crank, 9.4:1 c/r, Portflow head, stock GSR cams
Old Aug 11, 2005 | 02:59 AM
BlueShadow's Avatar
Default What timing for 83mm B18C, LS crank, 9.4:1 c/r, Portflow head, stock GSR cams
Hi guys,
My motor is getting assembled and will be getting dropped back in the car over the next couple of days. I'm gonna run it N/A until the car gets BAR certifieid. I'm debating whether I wanna run my stock P72, or if I wanna run my chipped P28 with a stock or lightly modded GSR map. I just needed to know where to set my timing with my setup. Like how much should I advance my whole timing map to make up for the increased bore size and lower CR? Also, will I be fine on stock GSR fuel maps, or should I richen it up a bit?
Thanks
Old Aug 11, 2005 | 12:24 PM
BlueShadow's Avatar
Default Re: What timing for 83mm B18C, LS crank, 9.4:1 c/r, Portflow head, stock GSR cams (BlueShadow)
bump
Old Aug 11, 2005 | 08:06 PM
BlueShadow's Avatar
DO A SEARCH NOOB!!!
oh wait, this is my thread isn't it?
ruffrhyder
Engine Management and Tuning
Oct 12, 2010 02:43 PM
madcrx69
Apr 18, 2010 06:49 PM
DarKStaR5
May 7, 2008 02:03 PM
tianporn
Apr 28, 2008 04:32 PM
Creator
Feb 8, 2008 04:19 PM
