transmission/motor mounts
im currently swapping a b18c type r engine into a 99civic si. Ive been reading the posts as to the required mounts and was wondering if i had the right idea. From what i understand all but the driver side mount are to be from the integra r and i should use the stock mount for the driver side. Anything will help. thanks.
You could you use your stock engine mounts if you'd like. Just need to change the timimg belt cover mount to a 99-00 Civic Si. Also we have a 5 peice complete upgrade mount kit for your car that replaces the factory gel driver side mount. Hope this helps.
Nova_Dust
Mar 14, 2008 04:40 PM
