How do I test the distributor coil and igniter?
Old Aug 10, 2005 | 10:03 PM
Sinner's Avatar
Default How do I test the distributor coil and igniter?
I have all the tools in the world, oscilliscopes, power sources, multimeters etc.. i just need to know how to test the distributor's parts? My car for the first time in 4 years left me stranded, it was because of the distributor(160k+ miles). This is the reason I want to know how to test it.
Nick
Old Aug 11, 2005 | 07:59 AM
JimBlake's Avatar
Default Re: How do I test the distributor coil and igniter? (Sinner)
Coil:
Primary & secondary resistance measured with simple ohm-meter. I don't remember the values. The other way for a coil to fail is insulation breakdown. So check each side with a meggar or something like that. You're looking for insulation breakdown to the case, especially from the secondary.
Ignitor:
It's an isolation amplifier of some kind. Feed it a pulsed signal, it shoud give a corresponding pulsed signal to the coil. So I guess a square-wave generator & oscilloscope??
CYP, CKP, TDC sensors:
Those are hall-effect sensors. Probably use an oscilloscope to watch while you spin the distributor shaft. I think those signals should not have continuity to ground, but they're not high voltage so an ohmmeter would be OK.
rollinswapshop
Mar 16, 2011 07:43 PM
rollinswapshop
Mar 15, 2011 03:11 PM
ILuvMyJdmDc4
Nov 27, 2007 05:17 AM
jjdickm
Mar 16, 2006 03:47 PM
boi_si
Dec 17, 2004 06:00 AM
