running rich, possible causes
Old Feb 21, 2002 | 06:37 PM
esuorps's Avatar
Default running rich, possible causes
I just replaced my head gasket on my 92 Prelude Si, 2.3 H23A1. Now it is running extremely rich. I am getting no codes when I jump the diagnostic connector. Anybody have any ideas?
Thanks,
Esuorps
Old Feb 22, 2002 | 04:01 PM
fixhondas's Avatar
Default Re: running rich, possible causes (esuorps)
TW sensor, cam timing, junk ignition parts, TPS, MAP, IAT, O2, bad grounds, the list goes on and on.
Old Feb 22, 2002 | 06:41 PM
esuorps's Avatar
Default Re: running rich, possible causes (fixhondas)
I suspect cam timing. When I install the timing belt I can never get the cam gears to line up completely straight. I mean I can line the cams using the alignment holes but as soon as the slack is taken out of the belt the intake cam ends up being retarded about a half a tooth. What's the deal with that? Is this normal?
Thanks again
Esuorps
Old Feb 22, 2002 | 06:58 PM
fixhondas's Avatar
Those can be a real bitch to line up- there are holes in the cams near the sprockets to help you hold them in place- usually you end up being off a tooth at the crank- I find that those office style paper clips or binder clips help to hold the belt on the sprockets during assembly- I clip the belt on the sprockets and pull it taught with two 12mm wrenches on the cam sprocket bolts then install it on the crank sprocket.
[Modified by fixhondas, 11:00 PM 2/22/2002]
masospaghetti
Jun 26, 2016 05:45 AM
scoob8000
Dec 19, 2011 11:57 AM
ZXRider
Dec 19, 2006 02:43 PM
1998HondaCivicLX4dr
Nov 27, 2004 05:10 PM
dustineck
Sep 25, 2003 10:19 PM
