90 crx dash in 90 civic Hb but the gauges dont work and the check engine glows
Old Aug 10, 2005 | 07:03 PM
kidrolla's Avatar
Default 90 crx dash in 90 civic Hb but the gauges dont work and the check engine glows
i did the swap to day got it all back in and when i went to start the car it starts but the check engine stays on, but when the car is turned off it still glows a lil bit. what could cause this. i changed out the main relay but i dont think its it cause it still runs just gauges dont work. when i hit the light the check engine gets brighter. could i have plug the wrong plug in some where.
Old Aug 11, 2005 | 06:09 AM
per4mance's Avatar
Default Re: 90 crx dash in 90 civic Hb but the gauges dont work and the check engine glows (kidrolla)
you have to re-pin the guage garness to match the crx gauge cluster.Thats why nothing works.Get a wiring diagram, or go to a junk yard cut out the crx gauge plugs, make sure its the right harness for you cluster, and then match up the colors.By this i mean re-pin your harness to match the crxs harness plugs.
border919
Dec 25, 2011 05:57 PM
dkrex001
Sep 26, 2007 04:12 PM
Broke EF
Feb 10, 2006 07:14 AM
bch5428
Sep 16, 2005 09:37 PM
