What Metric size bolts do Honda's never use?
Old Aug 10, 2005 | 06:52 PM
miksew's Avatar
Default What Metric size bolts do Honda's never use?
Just building up my tool collection and would like to know what sized metric bolts are never used on Honda's.
Just going through my tools and noticed lots of gaps in wrench and driver sizes and needed to know what I need and don't need in terms of sizes.
Thanks
Old Aug 10, 2005 | 07:07 PM
NJIN BUILDR's Avatar
Default Re: What Metric size bolts do Honda's never use? (miksew)
Mostly 8mm,10mm,12mm,14mm,17mm and some larger sizes.Most hardware store bolts use 13mm instead of 12mm.
Glenn
Old Aug 10, 2005 | 07:08 PM
veggiemaster's Avatar
Why not just buy a nice set of sockets rather then piece together what you "will" need?
Old Aug 10, 2005 | 07:52 PM
Rednas's Avatar
Default Re: What Metric size bolts do Honda's never use? (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">Why not just buy a nice set of sockets rather then piece together what you "will" need?</TD></TR></TABLE>
since you never know when you are going to need a tool you thought you didn't "need."
Old Aug 10, 2005 | 08:21 PM
Default Re: What Metric size bolts do Honda's never use? (Rednas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rednas &raquo;</TD></TR><TR><TD CLASS="quote">since you never know when you are going to need a tool you thought you didn't "need."</TD></TR></TABLE>
thats exactily what im saying. buy complete sets of tools rather than bits and pieces.
Old Aug 11, 2005 | 04:21 AM
v4lu3s's Avatar
RTFM
i use 8mm, 10mm, 12mm, 14mm, 17mm, 19mm, 22mm(certain sensors), 24mm(certain sensors), 27mm(certain sensors), 32mm and 36mm (both for axle nuts).
I do not recall ever using another size on a stock honda or acura.
I like to have one of each of the above in shall and deep socket 3/8 inch drive, the 8/10/12 in shallow and deep 1/4 inch drive, and then the 14 and larger in deep socket 1/2 inch drive.
i also have a bucked or 9, 11, 13, 15, and other odd sized sockets that i so rarely use...usually only when someone brings a car in to the shop that has had hardware store bolts put in it....
D16SohcVtec
Feb 16, 2008 02:00 PM
civicandr6
Honda S2000
20
Apr 18, 2007 08:30 PM
Shaun98si
13
May 6, 2005 08:46 AM
Beezle
Feb 12, 2005 03:30 PM
jeremy.
Jan 22, 2005 04:46 PM
