97 accord shifter problem help
Old Aug 10, 2005 | 06:41 PM
luckypon7's Avatar
Default 97 accord shifter problem help
ok, shifter is not releasing, i beleave the shifter solenoid is bad. i have to step release step release in order for the solenoid to kick in, sometime longer. where is the shifter solenoid located?
Old Aug 10, 2005 | 08:04 PM
hondadude's Avatar
Default Re: 97 accord shifter problem help (luckypon7)
The shift interlock solenoid is under the shift console. You have to remove the center console between the seats and then you'll be able to see the shift solenoid.
I have had bunches of these that just got gummed up from coffee/cola spillage, it might be worth a try to spray the plunger with WD-40 and work it a little bit.
lilvietboy
Mar 1, 2009 05:33 PM
tommyleeruiz
Jul 20, 2007 04:49 PM
onelow10
Jun 19, 2007 01:50 PM
JDMJunior
Jan 29, 2006 10:50 AM
sohctodohc
Oct 3, 2004 06:43 PM
