can i use a 6 puck disc on my CM stg 3?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj »</TD></TR><TR><TD CLASS="quote">can i just use a CM 6 puck disc? i assume the the PP are the same between stg3 and stg4</TD></TR></TABLE>
Yes you can, np. The Pressure plates may not be the same but they can and will work together.
ok...i'm assuming it will hold more power using the 6 puck with the stg 3 disc and not have a negative effect...hehehe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj »</TD></TR><TR><TD CLASS="quote">ok...i'm assuming it will hold more power using the 6 puck with the stg 3 disc and not have a negative effect...hehehe</TD></TR></TABLE>
You mean the Six puck disc with the Stage 3 Pressure Plate? Yeah
E36 Guy
Apr 5, 2004 09:03 PM
StreetwizeRacin2
11
Mar 30, 2004 03:53 PM
