Head Gasket for turboed EK.
Old Aug 10, 2005 | 06:10 PM
TurboHatch00's Avatar
Default Head Gasket for turboed EK.
I did a search and didn't find much.
I blew the stock gasket and have been looking everywhere, and most of them don't sound too promising.
Can anyone tell me what a good head gasket would be for a 2000 sohc vtec with 12 pounds of boost?
Thanks ,
Chris
Old Aug 10, 2005 | 06:11 PM
pdiggitydogg's Avatar
I dont think you searched very well...
Look into Cometic
Old Aug 10, 2005 | 06:13 PM
chad's Avatar
Moderator
Default Re: Head Gasket for turboed EK. (TurboHatch00)
stock headgasket with arp head studs!
Old Aug 10, 2005 | 06:14 PM
Default Re: Head Gasket for turboed EK. (chad)
Will Arp headstuds help prevent the gasket from blowing though?
Old Aug 10, 2005 | 06:15 PM
Default Re: (pdiggitydogg)
And in all honesty I searched my assoff, and never even came accross cometic. Thanks guys!
Old Aug 10, 2005 | 06:38 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboHatch00 &raquo;</TD></TR><TR><TD CLASS="quote">Will Arp headstuds help prevent the gasket from blowing though?</TD></TR></TABLE>
no keeps the studs from stretching which causes gasket to go...
Old Aug 10, 2005 | 07:41 PM
blackeg's Avatar
yea chad is 100% right.
Old Aug 10, 2005 | 07:58 PM
eK9aT10pSi's Avatar
also help prevent the head lifting during boost. i am too also looking into the cometic HG. they make HG for boost by using copper seals. d16y8 stock bore is 75mm [i belive] but they only list a 75.5mm. so im assuming you have to bore it a tad?
Old Aug 11, 2005 | 09:31 AM
Default Re: Head Gasket for turboed EK. (eK9aT10pSi)
I went ahead and called up a technician, and he said for the cometic head gasket you would want a 75.5 m (for d16y8). So no boring is involved.
Old Aug 11, 2005 | 09:43 AM
jmcmil6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">stock headgasket with arp head studs!</TD></TR></TABLE>
yeah check out golden eagles web site.. they use stock headgaskets on all their race cars!.. i made the mistake of using a cometic headgasket and.. yeah.. well im not making that mistake again..
fyi. another way not to blow the headgasket is= good tuning!
good luck
Old Aug 11, 2005 | 12:03 PM
and what was your mistake in buying a cometic? Youre the first Ive ever read of anyone having a problem with them (unless Im totally oblivious to other posts about them...which could also be the case...)
Old Aug 11, 2005 | 01:05 PM
jmcmil6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">and what was your mistake in buying a cometic? Youre the first Ive ever read of anyone having a problem with them (unless Im totally oblivious to other posts about them...which could also be the case...)</TD></TR></TABLE>
im in very very .. repeat very rough stages of learning to tune my car, but have been doing so, the hard way for a couple years now.. i kept burning up stock headgaskets trying to run hi-boost on 91 on an h22.. i've had the motor upwards of 26psi on pump and manage to blow a couple gaskets in the process..
a friend of mine and shop owner advised me not to try a cometic gasket after a motor he built(all motor) blew through one w/ lil effort--- so i install one taking a chance that it would hold up better than a stock one.. well it lasted a whole day.. on "less" boost... and it blew so bad... i ended up stranded on the side of the road w/ my motor pissing coolant into the exhaust and smoking everywhere.. of course i know it had alot to do w/ my tune.. but apparently the stocker was able to hold up for weeks at least.. but 1 day?!... after doing some research i decide to rebuild a block and have my machining done by GE.. odd.. they suggest using stock headgaskets on hondas.. they even use them on their race cars... after my experience and their results from their race cars.. . well take it for what thats worth. personally i wouldnt try another one again.
Old Aug 11, 2005 | 08:41 PM
eK9aT10pSi's Avatar
can anyone else confirm/back that up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboHatch00 &raquo;</TD></TR><TR><TD CLASS="quote">I went ahead and called up a technician, and he said for the cometic head gasket you would want a 75.5 m (for d16y8). So no boring is involved. </TD></TR></TABLE>
Old Aug 12, 2005 | 07:33 AM
Well, I'll tell you one thing. It should be close to enough. If the technicial lied it's called misrepresentation and is liable for a law suit. What he stated is more than puffery.
Agito
Sep 29, 2008 02:18 PM
ARACER25
Oct 23, 2003 10:31 PM
S13 slide
Jan 4, 2002 06:20 PM
therealnapster
Sep 10, 2001 01:32 PM
