Code 57
Alright im throwing a Code 57 on my 97 Civic HX but i searched and there is no code 57 so i thought i was doing it wrong and looked for Code 67 but there also isn't one. so if somebody could tell me what a Code 57 and 67 is.
TIA
TIA
Well to check it is the same as you would check it on a 92-95 civic. Because on the fourm https://honda-tech.com/zerothread?id=1171263 it only tells you how to check it on a 92 -95 and my car is a 97
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 »</TD></TR><TR><TD CLASS="quote">Well to check it is the same as you would check it on a 92-95 civic. Because on the fourm https://honda-tech.com/zerothread?id=1171263 it only tells you how to check it on a 92 -95 and my car is a 97</TD></TR></TABLE>
same way on 97
same way on 97
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 »</TD></TR><TR><TD CLASS="quote">What do the numbers with the "P" in front mean?</TD></TR></TABLE>
what p??
what p??
if you go the the thread :https://honda-tech.com/zerothread?id=1171263 and go down a little bit it gives codes that start with "P"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 »</TD></TR><TR><TD CLASS="quote">if you go the the thread :https://honda-tech.com/zerothread?id=1171263 and go down a little bit it gives codes that start with "P"</TD></TR></TABLE>
you have to have a code reader to get thsoe....you won't get them from jumping the harness...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 »</TD></TR><TR><TD CLASS="quote">alright then well im just going to go to auto zone and use there code reader to see what it says. thanks</TD></TR></TABLE>
turbotime
Jul 20, 2003 08:11 AM
