Code 57
Old 08-10-2005, 05:35 PM
skrewdriver88's Avatar
Default Code 57
Alright im throwing a Code 57 on my 97 Civic HX but i searched and there is no code 57 so i thought i was doing it wrong and looked for Code 67 but there also isn't one. so if somebody could tell me what a Code 57 and 67 is.
TIA
Old 08-10-2005, 05:44 PM
Moderator
chad's Avatar
Default Re: Code 57 (skrewdriver88)
you are reading the code wrong!
Old 08-10-2005, 06:25 PM
Default Re: Code 57 (chad)
Well to check it is the same as you would check it on a 92-95 civic. Because on the fourm https://honda-tech.com/zerothread?id=1171263 it only tells you how to check it on a 92 -95 and my car is a 97
Old 08-10-2005, 06:26 PM
JDMlyfestyle's Avatar
The codes apply for OBDI and OBDII cars
Moderator
chad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 &raquo;</TD></TR><TR><TD CLASS="quote">Well to check it is the same as you would check it on a 92-95 civic. Because on the fourm https://honda-tech.com/zerothread?id=1171263 it only tells you how to check it on a 92 -95 and my car is a 97</TD></TR></TABLE>
same way on 97
Old 08-10-2005, 06:32 PM
What do the numbers with the "P" in front mean?
Old 08-10-2005, 06:33 PM
Moderator
chad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 &raquo;</TD></TR><TR><TD CLASS="quote">What do the numbers with the "P" in front mean?</TD></TR></TABLE>
what p??
Old 08-10-2005, 06:35 PM
if you go the the thread :https://honda-tech.com/zerothread?id=1171263 and go down a little bit it gives codes that start with "P"
Old 08-10-2005, 06:36 PM
the P codes are codes what would come from a code reader. from the OBD2 scanport
Moderator
chad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 &raquo;</TD></TR><TR><TD CLASS="quote">if you go the the thread :https://honda-tech.com/zerothread?id=1171263 and go down a little bit it gives codes that start with "P"</TD></TR></TABLE>
you have to have a code reader to get thsoe....you won't get them from jumping the harness...
Old 08-10-2005, 06:41 PM
alright then well im just going to go to auto zone and use there code reader to see what it says. thanks
Old 08-10-2005, 06:43 PM
Moderator
chad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 &raquo;</TD></TR><TR><TD CLASS="quote">alright then well im just going to go to auto zone and use there code reader to see what it says. thanks</TD></TR></TABLE>
turbotime
07-20-2003 08:11 AM
reaction360
05-10-2003 03:53 PM
JDMINTEGRAGUY
11-16-2002 06:15 AM
turbocoupe
02-23-2002 11:47 PM
Quick Reply: Code 57
