Please Help Troubleshoot a B18A swap in to EG!!!
Old Aug 10, 2005 | 04:00 PM
Xgen's Avatar
Default Please Help Troubleshoot a B18A swap in to EG!!!
Ok, the engine is in, everything is hooked up, and all the wires are where they are supposed to be, but the car wont start, not only that, as soon as I plug in my battery terminal 3 red lights go off on the cluster, one for seatbelt, one for battery and one for SRS(airbag) they stay on despite if the keys are in the ignition or not, I have no clue what is wrong, i've tried everything pretty much and same results.
Anyone who went through this, please help.
Old Aug 10, 2005 | 04:04 PM
Jizzmaster Zero's Avatar
(banned)
Default Re: Please Help Troubleshoot a B18A swap in to EG!!! (Xgenturbo)
Sounds like to swapped it wrong
Old Aug 10, 2005 | 05:10 PM
unknown0001's Avatar
Default Re: Please Help Troubleshoot a B18A swap in to EG!!! (Jizzmaster Zero)
bump for some advice...car needs to be running
Old Aug 10, 2005 | 05:39 PM
LShatchie's Avatar
Default Re: Please Help Troubleshoot a B18A swap in to EG!!! (Mr.RHTuner)
What do you mean the car wont start? Does it atleast turn over?
Old Aug 10, 2005 | 05:41 PM
chad's Avatar
Moderator
you might have gotten the 2 wires that go into the engine bay fuse box switched....check those....
Old Aug 10, 2005 | 05:52 PM
Xgen's Avatar
Default Re: Please Help Troubleshoot a B18A swap in to EG!!! (LShatchie)
It dosnt even turn over
Old Aug 10, 2005 | 05:55 PM
LShatchie's Avatar
Sounds either like a wiring problem or do you know for sure if that starter works?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">Sounds either like a wiring problem or do you know for sure if that starter works? </TD></TR></TABLE>
Starter worked before the motor was pulled from the teg
Old Aug 10, 2005 | 05:56 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xgenturbo &raquo;</TD></TR><TR><TD CLASS="quote">It dosnt even turn over
DID YOU READ.....
switch those 2 wires in the engine fuse box!!! DUH
Old Aug 10, 2005 | 06:29 PM
LShatchie's Avatar
Default Re: Please Help Troubleshoot a B18A swap in to EG!!! (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">DID YOU READ.....
switch those 2 wires in the engine fuse box!!! DUH</TD></TR></TABLE>
What wires are you talking about? I dont remember doing this when I did my b18a swap.
Old Aug 10, 2005 | 06:30 PM
chad's Avatar
Moderator
What wires are you talking about? I dont remember doing this when I did my b18a swap.</TD></TR></TABLE>
you had to do it to do the engine swap!!!
Old Aug 10, 2005 | 06:32 PM
LShatchie's Avatar
Uh, I did my swap myself and I never did this? Could you maybe describe it better, cause if this is something I was supposed to do then I wana fix it.
Old Aug 10, 2005 | 08:28 PM
Xgen's Avatar
Switching the wires didint help at all, still the same results, its wierd.
Old Aug 10, 2005 | 08:45 PM
LShatchie's Avatar
Default Re: (Xgenturbo)
are all the grounds hooked up ?
Old Aug 10, 2005 | 08:50 PM
Xgen's Avatar
Default Re: (LShatchie)
Yes, even if they werent, the ignition lights would not be on without the keys in the ignition and turned, but they do as soon as I hook up the battery, its wierd, its like the car is trying to tell me something but I cant find any info on what it is.
Old Aug 10, 2005 | 09:07 PM
LShatchie's Avatar
Oh I understand what ur saying now.... it has to be some sort of wiring problem or short... just doesnt make sense
Old Aug 10, 2005 | 09:33 PM
99 civic si's Avatar
its either a short or a wiring mistake.
Old Aug 11, 2005 | 01:51 PM
Default Re: (99 civic si)
Here's an update:
Reason the car wasn't starting yesterday was due to lack of grounds so today when I went to Xgen's place the car would crank.
we made sure everything was hooked up and kept trying to crank it and crank it giving it some gas and eventually it started up. It ran rough so we played around with the spark plug wires and the motor ran perfectly.
After a few min we gave it some gas and the motor died...and wouldn't turn back on.
We checked the connections over and everything seems fine. The car doesn't seem to be giving off a spark and now it just keeps turning over.
Any ideas?
Old Aug 12, 2005 | 08:59 AM
Default Re: (Mr.RHTuner)
Old Aug 12, 2005 | 10:31 AM
moyo_rican's Avatar
RULES FOR YOUR SWAP
1. Dont do backyard swaps if you dont have backyard mechanics to work on them.
2. Always make sure you know what the hell you are doing.
3. Always make sure you have the proper tools and parts.
4. Do your research! Think it over for a while before you do it.
5. Why the hell you putting that old *** motor in your car Son?
Site123
23
Dec 9, 2008 04:57 PM
prototype2
Jun 26, 2008 05:05 PM
my_hidden_romance
Jul 27, 2007 09:51 AM
EIT_certified
Sep 24, 2004 12:51 AM
