Shift rod replacement recommendations
I am replacing the shift rod #14 and installing a short shifter #1. Helms manual says to replace #25 the o-rings and spring pin #29. Previously, I installed the Energy Suspension shifter bushings.
1) What is the best lubricating grease?
2) Is there anything else I should consider replacing while I am in there as the car is 16 years old? Dust seals #7 ($12) & #12 ($8)? Boot #6 ($14)?
Replace the shifter bushing, #8. Lubricate with a silicone paste, Shin-Etsu grease is nice, but maybe $, I dunno, I never pay for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">#16 and #18 ARE included in the master set i have one, only #16 doesnt fit if you have a b swap you have to buy the b- one</TD></TR></TABLE>
You know what, you are right...they ARE indeed included. I forget that I bought mine used and the guy took 'em out so I had to order a new kit. My bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dewarcr »</TD></TR><TR><TD CLASS="quote">What about #8? Is it in with the ES SHIFTER bushing kit?</TD></TR></TABLE>
Nope, but it would be wise to buy a new one. My shifter had play, then i changed #8 (about $10) and no play
. I also changed #12 (mine had a tear) so no dirt can get in and prematurely wear out #8.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dewarcr »</TD></TR><TR><TD CLASS="quote">Well damn. How about #7?</TD></TR></TABLE> Only #18 and 16 come in the ES kit, as stated earlier.
Thats another dust boot. Check yours for rips/tears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">Replace the shifter bushing, #8. Lubricate with a silicone paste, Shin-Etsu grease is nice, but maybe $, I dunno, I never pay for it.
I looked in my factory service manual for the 93 Integra about this bushing, if i can recall correctly (because i just changed #8 out) no lubricant was called for.
</TD></TR></TABLE>I looked in my factory service manual for the 93 Integra about this bushing, if i can recall correctly (because i just changed #8 out) no lubricant was called for.
1.8Tities
Sep 30, 2002 02:42 PM
