b18c type r swap into 99 civic si
Im in the midde of swapping the engine and find that my side mount and rear mount don't align. does anyone know if their are mounts made for this type of conversion?
Also i havnt' figured out how to do the wiring conversion. The engine is from japan. is there a harness or conversion that is manufactured to just plug in to both ends.
The last problem that i have is that it seems that the current cooling system will not be sufficient to cool this new larger engine. Has anyone run into this same problem? What should i do?
want to attempt the same conversion..
I was under the impression on the driver side mount needs to be changed.. the rear one looks the same..
and what did u do about the engine harness? would our 99si EM1 harness plug str8 into the b18c5/7 one?
1 more things..--
do we need to upgrade fuel pump and radiator?
thanks dude!
1 more things..--
thanks dude!
